Rear axle breather #2143616
08/30/16 02:23 AM
08/30/16 02:23 AM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
I have a 1970 Dana 60 that is missing the breather, which makes attaching the brake line block rather difficult. Does anyone reproduce these or do I just hit the boneyard?
Re: Rear axle breather [Re: 2JcodeChargers] #2143630
08/30/16 03:04 AM
08/30/16 03:04 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Mancini Racing has them.
Re: Rear axle breather [Re: 2JcodeChargers] #2143638
08/30/16 03:50 AM
08/30/16 03:50 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I thought the reproduction was a let done so I would hit the wrecker
Re: Rear axle breather [Re: Morty426] #2144323
08/31/16 01:03 AM
08/31/16 01:03 AM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
I thought they were still available from Chrysler
Re: Rear axle breather [Re: 2JcodeChargers] #2144573
08/31/16 02:41 PM
08/31/16 02:41 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Dr Diff lists one, is it a decent reproduction or?
Breather
Re: Rear axle breather [Re: 2JcodeChargers] #2144700
08/31/16 05:40 PM
08/31/16 05:40 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I have to say the one Dr. Diff sells looks really close to the original one on my Dana.
Re: Rear axle breather [Re: B5Cuda440-6] #2144764
08/31/16 06:48 PM
08/31/16 06:48 PM
MD
floyd Offline
floyd  Offline
MD
I bought one from Frank Badalson.
Re: Rear axle breather [Re: floyd] #2144899
08/31/16 09:40 PM
08/31/16 09:40 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
From ICCA
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Rear axle breather [Re: 2JcodeChargers] #2145655
09/01/16 08:23 PM
09/01/16 08:23 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
2J, hit your dealer or go shop online . section 3-02-20 in your parts manual listed # 2404119 which sups to #4032798. $25 . or for $5 use the one for a 4x4 and run a vent hose up to the tank-upper shock frame if its just a driver mopar #52067508. ronnie
Re: Rear axle breather [Re: 1969ronnie] #2145804
09/01/16 11:55 PM
09/01/16 11:55 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Unless something has changed, the breather that is currently available through Chrysler is not correct in appearance. Sure it will work, but is not correct. I have found the correct style available from Right Stuff and added them to our parts listing. The one difference is that they are now in a silver zinc finish where the originals were a gold cad finish. And they are priced reasonably at $10.00 each
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Rear axle breather [Re: 2JcodeChargers] #2145839
09/02/16 12:42 AM
09/02/16 12:42 AM
1969ronnie Offline
1969ronnie  Offline
the mopar 4032798 is gold cad and identical to original.
Re: Rear axle breather [Re: 2JcodeChargers] #2146527
09/03/16 12:28 AM
09/03/16 12:28 AM
2
Lots of good info. Thanks everyone for your input.
