for folks who have had their springs re-arched
#2142605
08/28/16 05:57 PM
08/28/16 05:57 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i know i'm over thinking this but - what is the procedure? can you just take your springs to a spring shop and ask to have 2 more inches of lift? it would seem they would need the car but is it a trial and error type of deal? bend them a little, trial fit, bend a little more and so on. can you just tell them your needs and they can make you an extra leaf to do that? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) i'm working up to a winter rear end rebuild and would like to ditch the air shocks. thanks!
Re: for folks who have had their springs re-arched
[Re: mikemee1331]
#2142694
08/28/16 09:01 PM
08/28/16 09:01 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Our spring shop has the specs for OEs.They did the kids 62 300s and added one inch arch and an extra leaf.His car sat great and when he sold the car they were on for at least 14 years.Still never weakened.We use Emch spring here.They even had a new set for my 57 Chrysler when I bought it.Rocky
Chrysler Firepower
[Re: SportF]
#2142764
08/28/16 10:23 PM
08/28/16 10:23 PM
RapidRobert
ask your shop if they just need the main arch(s). if so clamp them several inches away from the center bolt on each side of it & I would crack that nut with a nut cracker then remove the nut/bolt & undo the clamps evenly. that is a special bolt & the threads tend to get boogered up from road debris & if the nut is tight & you crack the bolt with using just a wrench then you'll have to search for a new one
[Re: mikemee1331]
#2142886
08/29/16 01:32 AM
08/29/16 01:32 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
not trying to be ignorant here but is there a benefit to the shocks with springs or are they as bad as air shocks when it comes to planting? The shock upper and lower bolts were designed to carry the load of just the shocks only, not the weight of the car's rear as would be the case for shocks with springs or air shocks. Using air shocks or shocks with springs risks bending or shearing the attachment bolts which are cantilevered and supported on only one end. I added one leaf to each side about 1976 due to severe wheel hop on acceleration. This raised the rear body about 1.5 inches. Still good today with zero sag after 40 years.
[Re: killermopar]
#2142893
08/29/16 01:44 AM
08/29/16 01:44 AM
RapidRobert
Napa usually has tons of center bolts in stock Noted, thank you!
[Re: mikemee1331]
#2142917
08/29/16 03:12 AM
08/29/16 03:12 AM
therocks
Niles , Ohio
Any spring shop that dosent have the center bolts run away from very very fast.No need to seperate the springs.just bring them to the shop.Check the bushings also.Bringing the complete spring is best that way they can make sure none are broke or bad.Rocky
Chrysler Firepower
[Re: kentj340]
#2142966
08/29/16 08:56 AM
08/29/16 08:56 AM
mikemee1331
bethlehem pa
I added one leaf to each side about 1976 due to severe wheel hop on acceleration. This raised the rear body about 1.5 inches. Still good today with zero sag after 40 years. this seems to be the best direction. 1 1/2 would be plenty. wheel hop is not my issue. i just can't get a grip. i'm running MT 29x15x15 so that shouldn't be an issue. i'm sure it's because of the air shocks thanks guys!
[Re: mikemee1331]
#2143058
08/29/16 11:46 AM
08/29/16 11:46 AM
Posts: 8,351 fredericksburg,va
cudaman1969
fredericksburg,va
I added one leaf to each side about 1976 due to severe wheel hop on acceleration. This raised the rear body about 1.5 inches. Still good today with zero sag after 40 years. this seems to be the best direction. 1 1/2 would be plenty. wheel hop is not my issue. i just can't get a grip. i'm running MT 29x15x15 so that shouldn't be an issue. i'm sure it's because of the air shocks thanks guys! Back in the day I bought a 69 RR that had used air shocks, they had torn the top cross member completely from the frame. Welded it back the best I could then later after getting the good parts off, sold it. Bought the car cheep $250 Air shocks are a no-no
[Re: mikemee1331]
#2143149
08/29/16 02:18 PM
08/29/16 02:18 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
For the best results the car should be at the shop and adjusted until it sits where you want it.
Just understand adding a leaf will increase the spring rate. Not always a bad thing since most cars from the 60's are too soft to begin with. The problem I find is stock to 1 added is too big of a jump in spring rate.
[Re: mikemee1331]
#2145677
09/01/16 08:52 PM
09/01/16 08:52 PM
Posts: 12,294 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
well i found a shop in my area and they recommended re-arching and an extra leaf. $125 each side.
next question would be (and i have searched it)i won't be able to use a standard B-body shock, right?
i have read that a C-body shock is the way to go, true? just any 1969 C-body? i wouldn't think the actual shock length would be any different $125 each side to re-arch? New stock spec springs are only about $150 a side. I would suggest that you get the re-arched springs on and see how the shocks look before you decide. If they are too short, you can also use shock extenders and your current shocks.
Master, again and still
[Re: mikemee1331]
#2145679
09/01/16 08:54 PM
09/01/16 08:54 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
well i found a shop in my area and they recommended re-arching and an extra leaf. $125 each side. Take them to Reading Spring in Reading PA. Had mine rearched and added another leaf, still retains the same rake after 15 years.
[Re: Pntastar69]
#2145693
09/01/16 09:26 PM
09/01/16 09:26 PM
RapidRobert
I agree $125 is way too much. you might see what they want just to rearch the (2) main leaf(s) & you would break em down/reassemble. just need 2 good sized C clamps
