What is this sb Mopar part in gasket set?
#2142646
08/28/16 07:35 PM
08/28/16 07:35 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
This is my first sb Mopar...what is this that was in the sb gasket set?
Re: What is this sb Mopar part in gasket set?
[Re: Quicksilver440]
#2142649
08/28/16 07:37 PM
08/28/16 07:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What is what?
Not seeing anything.
#2143208
08/29/16 04:32 PM
08/29/16 04:32 PM
RapidRobert
What Oz said, extra external protection for the seal (goes on the dampener snout). dont forget to just start the tcover screws part way then install the dampener so its snout is past the seal which will "center" the seal/tcover then finish the tcover bolts then draw the dampener on the rest of the way. unlike a BB, the SB tcover is a loose fit
#2143236
08/29/16 05:56 PM
08/29/16 05:56 PM
RapidRobert
we're here to help each other bro. Another caveat, sometimes the t cover bolt on the fuel pump side right behind the water pump nipple (if using later alum pump), it is about halfway up, is too thick & can keep the water pump from sitting flush on the tcover. visual and or mockup dry with gasket/no sealer to elim that. some bolts go into coolant so be sure to use cement on their threads. EDIT some I have had to trim the bolt head to about half its height, but there is still enough meat to get a wrench on it with the pump installed cuz I like to torque all the bolts down evenly tho some you wont be using a torque wrench on, just (helps) keep Mr Murphy at bay
[Re: buildanother]
#2143245
08/29/16 06:03 PM
08/29/16 06:03 PM
RapidRobert
yes, the open face of the seal should face rearward. EDIT set the pump gasket dry on the pump and the tcover face then flip it over, as some gaskets have a slightly different non symmetric curve that you can see when you look for that & they conform to the outline of the pump/tcover moderately better with it flipped the right way, then make a P on the side that faces the pump for install reference. most of those gaskets I have seen are the non symmetric ones & need to be on the right way & it is a easy check to do
#2143860
08/30/16 01:56 PM
08/30/16 01:56 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Thanks for the tip Robert....that (and sb's) is new to me! I wouldn't have known to do that... I've NEVER had to do it , maybe I'm just good ?? Or lucky ??? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
