Original plug wires? #2142376
08/28/16 11:38 AM
08/28/16 11:38 AM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Could anyone tell me how to tell if some plug wires are repops or original?
I have a set from when I bought the R/T but they look pretty nice.
Re: Original plug wires? [Re: LimeliteAero] #2142378
08/28/16 11:40 AM
08/28/16 11:40 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Post a few good close ups of the script on them as well as the distributor boots
Re: Original plug wires? [Re: ScottSmith_Harms] #2142395
08/28/16 12:16 PM
08/28/16 12:16 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Date codes will be a give away also.
Re: Original plug wires? [Re: LimeliteAero] #2142414
08/28/16 12:52 PM
08/28/16 12:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Reproductions have date codes as well, the differences between OEM's and reproductions are quite subtle but they exist.
Re: Original plug wires? [Re: ScottSmith_Harms] #2142416
08/28/16 12:56 PM
08/28/16 12:56 PM
SE Pa.
SE Pa.
Im guessing repops because of the condition but here are two. I can get more.
Thanks!
Re: Original plug wires? [Re: ScottSmith_Harms] #2142417
08/28/16 12:58 PM
08/28/16 12:58 PM
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
What I meant to say is that all the reproductions have the same date codes (ex 70 wires are 3rd qt of 69 if I remember right)and it normal to see on a set of original with 2 or more different date codes.Usually not a matched set.
Re: Original plug wires? [Re: LimeliteAero] #2142427
08/28/16 01:26 PM
08/28/16 01:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Is the distributor to coil wire boot 100% black or does it have a slight dark red hue to it?
Re: Original plug wires? [Re: ScottSmith_Harms] #2142441
08/28/16 01:39 PM
08/28/16 01:39 PM
SE Pa.
SE Pa.
all black boot and the wires are all dated H 3-67.
Re: Original plug wires? [Re: LimeliteAero] #2142499
08/28/16 03:09 PM
08/28/16 03:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep, sounds like repros.
Re: Original plug wires? [Re: LimeliteAero] #2142505
08/28/16 03:17 PM
08/28/16 03:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's an original coil wire boot
Re: Original plug wires? [Re: LimeliteAero] #2142507
08/28/16 03:21 PM
08/28/16 03:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
These are NOS wires (including the coil wire). Notice how the coil wire has white script? This was common.
