Re: Temp Gauge
[Re: ct440rod]
#2144181
08/30/16 10:29 PM
08/30/16 10:29 PM
Posts: 737 Michigan
BlueRacer69
Have 51 miles on 70 Challenger after 15 year rebuild. Have 180 thermostat and after driving couple miles the temperature gauge does not go above the 1st white mark by cold. Check around water pump with temperature scan gun and it reads about 175. Should the gauge needle be up higher ? ? thanks I would say YES. I didn't have a Challenger but I did have a brand new 69 Dart GTS back then. My temp gauge would always read right about 1/2 way/or right about in the middle of the gauge after the car was warmed up.
Re: Temp Gauge
[Re: ct440rod]
#2144492
08/31/16 11:46 AM
08/31/16 11:46 AM
Posts: 737 Michigan
BlueRacer69
My 69 Dart GTS was all stock back then, (it was brand new), with a 383 motor and 391 gears. Temp gauge needle always went to 1/2 way between cold & hot when engine was warmed up. I'm guessing yours should too if everything was in sink. I think all 70 Challengers came new with 195 stats.
Re: Temp Gauge
[Re: screamindriver]
#2145271
09/01/16 11:50 AM
09/01/16 11:50 AM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
You did'nt state the engine size..Is the 180 stat the correct factory value for your engine ??? As other's have suggested it's a matter of matching all the new components together and seeing where "normal" falls on the gauge for a known given temp..
Were the gauges rebuilt ??? Above post is where you need to start first....
Re: Temp Gauge
[Re: BlueRacer69]
#2145611
09/01/16 07:34 PM
09/01/16 07:34 PM
Posts: 5,450 So Cal
Sinitro
So Cal
My 69 Dart GTS was all stock back then, (it was brand new), with a 383 motor and 391 gears. Temp gauge needle always went to 1/2 way between cold & hot when engine was warmed up. I'm guessing yours should too if everything was in sink. I think all 70 Challengers came new with 195 stats. Standard thermostadt in 1970 was a 190.. Just my $0.02... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
