Lower Control Arms for a 1971 Plymouth Satellite #214222
02/04/09 06:50 PM
02/04/09 06:50 PM
Gibsonburg, Ohio USA
dodgem_doug Offline OP
I'm replacing the lower control arms and I'm wanting to upgrade to factory sway bar brackets already mounted on the lower control arms. I got a lead on the control arms but they're off a 1969 Dodge Charger. Are there any differences between the 1969 to 1971 "B" bodies?
Thanks, Doug
Re: Lower Control Arms for a 1971 Plymouth Satellite [Re: dodgem_doug] #214223
02/04/09 08:59 PM
02/04/09 08:59 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
The sway bar mounting tabs are in a differant location on the 70 and up lower control arms.
Re: Lower Control Arms for a 1971 Plymouth Satellite [Re: LTLBEE] #214224
02/04/09 09:16 PM
02/04/09 09:16 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Soooooooooo,
will that werk with the right sway bar?
Re: Lower Control Arms for a 1971 Plymouth Satellite [Re: bboogieart] #214225
02/04/09 10:38 PM
02/04/09 10:38 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
The lower control arms from 70-74 E bodys or 70-72 B bodys will work.
Re: Lower Control Arms for a 1971 Plymouth Satellite [Re: LTLBEE] #214226
02/05/09 12:26 AM
02/05/09 12:26 AM
minnesota
P
president61 Offline
president61  Offline
P
minnesota
Yep! the ones on my 71 Satellite came off a 70 Challenger
Re: Lower Control Arms for a 1971 Plymouth Satellite [Re: president61] #214227
02/05/09 01:30 AM
02/05/09 01:30 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
1970-74 cuda/challenger
1970-72 coronet, charger roadrunner, satellite, belvedere, superbee and GTX are all the same, even the 4-b-body cars will work.
Re: Lower Control Arms for a 1971 Plymouth Satellite [Re: bboogieart] #214228
02/05/09 10:52 AM
02/05/09 10:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Soooooooooo,
yes it would , but you'll have to drill holes in the K frame but if you have disc brakes with front mounted calipers the caliper will hit the swaybar before you get to full lock .
