Big Block Plug Wire Routing
#2125224
08/04/16 08:48 PM
08/04/16 08:48 PM
Posts: 542 SW CO
HemiSportFury
SW CO
I've been scratching my head on what is the best routing for RB/BB plug wires when using headers. The number 1 and 2 header tubes go above #3 and #4 and then down between 5-7 and 6-8. The front two plug wires on both sides are pretty easy to route from below the front tube, but the back cylinders are more of a challenge. It looks like the best route would be over the top of the valve covers. If so, how do you support them and keep them off the header tubes? The other option is to route them wide of the headers and lay them against/on top of the steering box and shock towers. This does not look very "neat" to me.
How about showing some pictures of how you have routed and supported your plug wires to give me some ideas. I'd like the plug wires to look neat and orderly, but the stock routing is not an option with headers.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Big Block Plug Wire Routing
[Re: HemiSportFury]
#2125249
08/04/16 09:18 PM
08/04/16 09:18 PM
Posts: 21,142 Niles , Ohio
therocks
Niles , Ohio
I run a set of looms from Summit.I think they are something like RJS ot like that.They go on top of the vcover at the bottom and wires go from 4 to 1 in the back.they are aluminum and do a nice job.Ran them on our cars all with headers.last set of wires was on 15 years.I did run a thermal sock on 7 because it was close.My 2 inch TTIs fit nicely with the looms and Taylor stock 440 lug wires.Rocky
Chrysler Firepower
[Re: therocks]
#2125271
08/04/16 09:46 PM
08/04/16 09:46 PM
Posts: 542 SW CO
HemiSportFury
SW CO
Do you have a picture of that setup?
[Re: HemiSportFury]
#2125313
08/04/16 10:29 PM
08/04/16 10:29 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have always run mine around the front and under. 71 Barracuda 70 Valiant 63 Plymouth
1963 Plymouth Max Wedge 1971 Barracuda
[Re: therocks]
#2125491
08/05/16 07:52 AM
08/05/16 07:52 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I run a set of looms from Summit.I think they are something like RJS ot like that.They go on top of the vcover at the bottom and wires go from 4 to 1 in the back.they are aluminum and do a nice job.Ran them on our cars all with headers.last set of wires was on 15 years.I did run a thermal sock on 7 because it was close.My 2 inch TTIs fit nicely with the looms and Taylor stock 440 lug wires.Rocky same here. up and over. i've got socks on all of them cause i got a good deal on ebay for a set of 8
[Re: mikemee1331]
#2125553
08/05/16 10:17 AM
08/05/16 10:17 AM
Posts: 5,203 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Mine on a 70 383... I made the small brackets for under the valve cover bolts to tuck the wires into.
...FAFO...
[Re: HemiSportFury]
#2125745
08/05/16 01:50 PM
08/05/16 01:50 PM
therocks
Niles , Ohio
Carnut has the pic posted.The looms are super nice.Mine have been on well over 15 years and they come with spacers to raise or lower the loom.Wires stay nice and tight in the holders with allen screws.Well worth the $$$.They even come in colors.We have run them on BBs and SBs with headers. Rocky
Chrysler Firepower
[Re: HemiSportFury]
#2126097
08/05/16 08:27 PM
08/05/16 08:27 PM
Posts: 542 SW CO
HemiSportFury
SW CO
Thanks for posting all the pictures. You guys do nice work. This will give me some ideas if I get a chance to work on the car this weekend.
[Re: 71rm23]
#2126657
08/06/16 05:21 PM
08/06/16 05:21 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
In relation to the OP's question: Does anyone know where to get the wire #'s for the wires? I think they clip on to the wire tNot certain now, perhaps it was Summit. Check EBay or Amazon.
[Re: Sxrxrnr]
#2126694
08/06/16 06:27 PM
08/06/16 06:27 PM
Posts: 2,592 None
71rm23
None
In relation to the OP's question: Does anyone know where to get the wire #'s for the wires? I think they clip on to the wire tNot certain now, perhaps it was Summit. Check EBay or Amazon. Thanks and your engine compartment looks good!
[Re: HemiSportFury]
#2126925
08/07/16 01:14 AM
08/07/16 01:14 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The best I can tell you is on my sons Dart (the blue wires) they are Taylor wires. And the black wires on my 63 are Firecore. I like both as they both worked good for us. And thanks for the kind words. Ron
[Re: HemiSportFury]
#2128055
08/08/16 05:28 PM
08/08/16 05:28 PM
Posts: 12,132 Cleveland
sunroofgtx
Cleveland
We sell the wire markers..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#2140748
08/25/16 06:06 PM
08/25/16 06:06 PM
Posts: 542 SW CO
HemiSportFury
SW CO
Thought I should update this post on what I ended up doing with my plug wires. I appreciate all the people that took the time to post a picture of their engines. It gave me some good ideas. I wound up routing the front two cylinders on both sides below the headers, and the back two above the headers. I put heat sleeves on 5 & 6 since they run fairly close to the header tubes. I used Spectra wire separators and made aluminum brackets that mounted to the valve cover bolts. The Taylor universal wire set was plenty long to allow routing of your choice. I'm happy with the result for what I have invested in it. Thanks for your help.
PS Don't mind the burnt header paint. That's a victim of breaking in a new cam. Probably take them off this winter and try again.
