727 Rear Clutch Retainer Assembly #2140676
08/25/16 04:50 PM
08/25/16 04:50 PM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
Hello,
As I assembled the rear clutch assy., I noticed that there is a gap between the spring and piston. Just wondering if this is O.K.? or is something worn?
When I measure the play in the assy. I am getting about .060" when I pull up on the input shaft with the assy setting on my bench, as in the pics.
Any comments or suggestions are more then appreciated.
Thanks, Jeff
Re: 727 Rear Clutch Retainer Assembly [Re: SlickRS23] #2140709
08/25/16 05:43 PM
08/25/16 05:43 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Perfectly normal.
Re: 727 Rear Clutch Retainer Assembly [Re: SlickRS23] #2140715
08/25/16 06:06 PM
08/25/16 06:06 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
Thanks John
