70 bbody steering wheel #2139577
08/23/16 10:26 PM
08/23/16 10:26 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I changed the steering head off my 70 satellite. Originally was column shift with after market steering wheel with tha adapter kit. Recently I changed the column shift head on the column to a floor shift column. Now the steering wheel is not going far enough down to disengage the turn signal. Is there a difference in size between floor shifter column head and the regular? HELP
Re: 70 bbody steering wheel [Re: roy2345] #2145730
09/01/16 10:07 PM
09/01/16 10:07 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Anybody ???
Re: 70 bbody steering wheel [Re: roy2345] #2145811
09/02/16 12:05 AM
09/02/16 12:05 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The top end of the column is e same. The problem is in the changes you made.
A different way to view this problem is that the turn signal switch is too far away from the steering wheel.
Re: 70 bbody steering wheel [Re: roy2345] #2145817
09/02/16 12:14 AM
09/02/16 12:14 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Did the pin or button fall out of the wheel adapter? On some adapters, there are 2 pin locations, and the adapter can be clocked in more then one direction. Its possible you have the adapter clocked in a different position then it was originally. Gene
Re: 70 bbody steering wheel [Re: roy2345] #2145917
09/02/16 03:45 AM
09/02/16 03:45 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yeah it sounds like the bottom part slide down.
There is no difference in shaft length or other parts between column shift and floor shift
Re: 70 bbody steering wheel [Re: roy2345] #2146236
09/02/16 04:26 PM
09/02/16 04:26 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Ok I'll try that... Thanks do much
