Big Block Headgaskets? #2139104
08/23/16 01:32 AM
08/23/16 01:32 AM
Fargo ND
moparphilll Offline OP
Fargo ND
Seems the new Headgaskets have restricted water jacket openings?
Re: Big Block Headgaskets? [Re: moparphilll] #2139119
08/23/16 01:51 AM
08/23/16 01:51 AM
you could go to www.moparchat.com then scroll down to & click on "circle track chat" then read thru Sanborns' cooling mods that are in a sticky at the top of the page. SB orientated but alot carries over & he's one of the sharpest in the country. it'll take you a good hour to read/reread/absorb it all but it is worth it then decide for yourself
Re: Big Block Headgaskets? [Re: moparphilll] #2139125
08/23/16 02:01 AM
08/23/16 02:01 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I've wondered about this in the past. Even drilled a set of gaskets once to match the block. Seemed to work okay, but I can't suggest it. Last couple of times I've had mine off I've just installed them accepting the pattern and have found that it actually it stays cooler, and here's (I think) why: you want the water to run front to back through the block, then return through the head, utilizing the large passages at the front & back. I believe this keeps coolant moving all the way to the back, and keeps the water flowing in a pattern. If the coolant was allowed to flow down through the gasket too much, you'd get hot-spots as it wouldn't flow all the way to the back. At least this is what seems to make sense to me.
Basically, install them and ignore the desire to see the gasket passages align with the block & head passages. It works, don't sweat it.
Re: Big Block Headgaskets? [Re: moparphilll] #2139143
08/23/16 03:03 AM
08/23/16 03:03 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yeah they're supposed to be that way
Re: Big Block Headgaskets? [Re: GTX MATT] #2139178
08/23/16 09:05 AM
08/23/16 09:05 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Cylinder blocks are sand castings. In many cases the various holes in the block and the size of those holes are there to allow removal of the sand after solidification in the casting process. My advice would be to leave the head gaskets the way the engineers designed them. Mismatch or missing holes in the gasket are not a mistake.
Re: Big Block Headgaskets? [Re: TooMany62s] #2139190
08/23/16 09:44 AM
08/23/16 09:44 AM
Fargo ND
Fargo ND
OK THANKS!!!
Re: Big Block Headgaskets? [Re: moparphilll] #2139212
08/23/16 10:46 AM
08/23/16 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is nothing new , felpro, and others including current Mopar steel shim, headgaskets have been like this for decades and it doesn't cause problems in 99.9999% of cases .
Re: Big Block Headgaskets? [Re: JohnRR] #2139314
08/23/16 02:43 PM
08/23/16 02:43 PM
dogdays Offline
dogdays  Offline
Yes, think of the holes as metering devices.
R.
Re: Big Block Headgaskets? [Re: moparphilll] #2139323
08/23/16 03:06 PM
08/23/16 03:06 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
I agree, I just chiseled out a clearly original set from a 40 year old untouched 440 and they had the slots like that...
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: Big Block Headgaskets? [Re: moparphilll] #2139528
08/23/16 08:49 PM
08/23/16 08:49 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
They are suppose the be restricted. You just want to have a bit of flow to prevent steam/air pockets. The coolant flow goes from front of block to back of block, up through back of heads to front of heads to thermostat.
Incorrectly enlarging the holes can show a lower thermostat temperature, but the back of the block will be running hot because you are bypassing the flow to the back of the block.
The exception to this might be increasing the hole to the next to last cylinder to help cool the center exhausts area of the head.
Re: Big Block Headgaskets? [Re: moparphilll] #2139726
08/24/16 01:59 AM
08/24/16 01:59 AM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
In my opinion, the small "slits" head gaskets were designed for '72 and later blocks shown in the bottom picture as they enlarged the water passages. The top picture is pre '72 block, if you put a those small "slit" head gaskets there is about 1/4" exposed, the rest is entirely covered, I believe the larger rectangular opening on the head gasket you posted was designed for pre '72 block. I have spoken to Greg at Superformance before as he has the template for the original Mopar Connection steel shim head gaskets, and his new reproduction have the larger rectangular slots.
However, I have run both on '68 block and have had zero issues with either design.
Re: Big Block Headgaskets? [Re: Banzaiii67] #2139774
08/24/16 09:29 AM
08/24/16 09:29 AM
Fargo ND
Fargo ND
I had not seen that, Have been using 906 or 915 closed chamber heads on pre 72 blocks, interesting bow
