Re: 70 Roadrunner Turn Signal Problem
[Re: a12rag]
#2138780
08/22/16 06:57 PM
08/22/16 06:57 PM
Posts: 2,640 Port Reading, NJ
roadrunner7070
Port Reading, NJ
OK. So where is the flasher located? I just see the emergency flasher unit. Everything has worked fine for the past 10 years.
[Re: roadrunner7070]
#2138788
08/22/16 07:06 PM
08/22/16 07:06 PM
Posts: 2,919 Calgary, Alberta Canada
a12rag
If I recall correctly, I think it is up under the dash on drivers side, might be clipped onto the lower part of metal dash panel, or the steering column support . . . according to wiring diagram from FSM, it is up against the drivers side of the ash tray . . .
[Re: a12rag]
#2138932
08/22/16 09:56 PM
08/22/16 09:56 PM
roadrunner7070
Port Reading, NJ
If I recall correctly, I think it is up under the dash on drivers side, might be clipped onto the lower part of metal dash panel, or the steering column support . . . according to wiring diagram from FSM, it is up against the drivers side of the ash tray . . . That is the emergency flasher unit next to the drivers side ash tray.
#2138946
08/22/16 10:20 PM
08/22/16 10:20 PM
RapidRobert
if your E flasher can is working, swap it for the TS one & if this straightens out the TS lights
[Re: RapidRobert]
#2138956
08/22/16 10:25 PM
08/22/16 10:25 PM
roadrunner7070
Port Reading, NJ
if your E flasher can is working, swap it for the TS one & if this straightens out the TS lights I cant find the turn signal flasher!!!!!!!!!!!!!!
#2139005
08/22/16 11:44 PM
08/22/16 11:44 PM
RapidRobert
stick your head back up under there & listen intently for those 3 (or 4) clicks!
#2139318
08/23/16 02:46 PM
08/23/16 02:46 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Not to be smart but maybe time to buy a factory service manual.Best money you will spend.Rocky
Chrysler Firepower
[Re: therocks]
#2139380
08/23/16 04:46 PM
08/23/16 04:46 PM
roadrunner7070
Port Reading, NJ
Not to be smart but maybe time to buy a factory service manual.Best money you will spend.Rocky I have the factory service manual. It says on left side of steering wheel.
