Re: show pics of your hemi motor mild-wow
[Re: Mr. Dodge]
#213862
02/05/09 01:39 AM
02/05/09 01:39 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Here's the one that I built for the book I'm writing. Dyno tested it yesterday.
14" vacuum at 800 RPM idle. 700 ft lbs at 3500 RPM. 725 HP at 6200 91 octane pump gas. EFI with coil-on-plug ignition.
Want a video of the dyno pull http://www.youtube.com/watch?v=5szbndxDbyE
[Re: CrAzYMoPaRGuY]
#213864
02/05/09 08:13 AM
02/05/09 08:13 AM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
The Indy valve covers do NOT require the longer tubes unless you use them on the Indy heads. I have Indy valve covers on stock MP heads w/ stock length tubes. CHIP
[Re: sunroofgtx]
#213876
02/06/09 07:15 PM
02/06/09 07:15 PM
an8sec70cuda
Thanks Chip. Looks like you do not have the Legend Heads/Valvecoves. I could be wrong, never seeing it up close. I was just pointing out those specific types. Indy has several different valvecover types. I am still in love with the look of the Dragula Truck with the Hemi in it.
I have the Legend covers on MP heads. From what I've seen, Indy doesn't have 2 different valve covers...one for stock tubes and one for the longer ones. All I'm saying is that if you use the Indy covers on heads other than Indy's, then you do not need the longer tubes. I believe the difference is in the heads, not the valve covers. CHIP
[Re: sunroofgtx]
#213879
02/06/09 09:23 PM
02/06/09 09:23 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Here`s a very mild FAST engine: ![](http://i32.photobucket.com/albums/d34/DaveDudek/th_8e5773a6.jpg)
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
