Tubing Notcher???
#2137519
08/20/16 10:46 PM
08/20/16 10:46 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I am looking at buying a tubing Notcher that uses a end mill bit for roll cages. Has anyone ever used a vertical Mill as a tubing notcher? I am thinking I can kill two birds with one stone.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Tubing Notcher???
[Re: 65 Hemi]
#2137539
08/20/16 11:37 PM
08/20/16 11:37 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I know this is not what you have asked but I have been in the steel fabrication game for over 30 years, done fair few cages and we notch or fishmouth our pipe by hand. Check out this site for your pipe wraps. http://metalgeek.com/static/cope_custom.pcgi
1963 Plymouth Max Wedge 1971 Barracuda
[Re: humpty]
#2137564
08/21/16 12:09 AM
08/21/16 12:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I used one of the cheap notchers for years.... but I rebuilt the shaft and put sealed bearings in it.. the bushings wear out pretty quick even being lubed... then I touch up the cuts with a oscillating drum sander ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: 6pakdakota]
#2137576
08/21/16 12:28 AM
08/21/16 12:28 AM
65 Hemi
San Diego CA
I was thinking the same thing and also a vertical mill can be picked up used for about half the price and can be used as a mill also. 👍🏻👍🏻👍🏻 A vertical mill works way better than the end mill style notchers. I have done hundreds of roll cages with one, but you will still need to freehand some notches. I also prefer a hole saw notcher over the endmill type. It is faster and provides a cleaner cut.
Doug
[Re: ozymaxwedge]
#2137580
08/21/16 12:31 AM
08/21/16 12:31 AM
65 Hemi
San Diego CA
Thanks for the link I know this is not what you have asked but I have been in the steel fabrication game for over 30 years, done fair few cages and we notch or fishmouth our pipe by hand. Check out this site for your pipe wraps. http://metalgeek.com/static/cope_custom.pcgi
Doug
[Re: 65 Hemi]
#2137584
08/21/16 12:40 AM
08/21/16 12:40 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Yes, I use a vertical mill for all my notching. I have a seriesII bridgeport with the larger collet set up. It works perfectly for notching and the auto feed saves holesaws/tooling.
[Re: 65 Hemi]
#2137623
08/21/16 01:29 AM
08/21/16 01:29 AM
ozymaxwedge
Australia
Thanks for the link I know this is not what you have asked but I have been in the steel fabrication game for over 30 years, done fair few cages and we notch or fishmouth our pipe by hand. Check out this site for your pipe wraps. http://metalgeek.com/static/cope_custom.pcgi ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Here's one we done the other day, 37deg. ![](http://i113.photobucket.com/albums/n209/maxwedge63/IMG_3033_zpscetfy0p9.png)
[Re: 65 Hemi]
#2137651
08/21/16 02:38 AM
08/21/16 02:38 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I have a Woodward Fab one, solid and reliable. Use plenty of oil and drill on low.
Mopar to the bone!!!
[Re: 72Swinger]
#2137884
08/21/16 01:55 PM
08/21/16 01:55 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I have a Woodward Fab one, solid and reliable. Use plenty of oil and drill on low. I was always told to never use oil. Soapy water to keep it cool? I'm I doing this wrong? Matt
[Re: MattW]
#2137918
08/21/16 02:34 PM
08/21/16 02:34 PM
Posts: 11,819 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have a Woodward Fab one, solid and reliable. Use plenty of oil and drill on low. I was always told to never use oil. Soapy water to keep it cool? I'm I doing this wrong? Matt I used to use oil on my hole saw notcher. Makes a mess that has to be cleaned inside and out before welding. I've been using it dry for a while now. I see no difference in saw life. Feed and drill speed are what you have to pay attention to for saw life and not making it too hot. As far as the OP's question, I would think an indexable vise for tubing and the correct bit would be all that is needed to notch tubing on a mill. Tooling is obviously more expensive and I'd be interested to know how long the cutters last when cutting CM. Mittler and Baileigh make nice machines, but I don't know how you justify the cost for one of those in the majority of shops. Have to be turning out a lot of cars. A GOOD holesaw notcher (one that's not flimsy and waving in the breeze with a long piece of tubing in it) makes just as nice of a notch and can typically cut a notch closer to a bend than the machines with the larger vises. JD2 is making the nicest holesaw type notchers that I see for sale now.
[Re: 65 Hemi]
#2138214
08/21/16 11:07 PM
08/21/16 11:07 PM
TRENDZ
Milwaukee WI
Once you use a mill you will never want to use a notcher. I can use the same single holesaw on chromoly tubing over and over and over. I would estimate a 1 5/8 holesaw gets me around 30 perfect cuts before I switch it out. No coolant/lube. You would be way farther ahead buying a used mill than a new notcher.
[Re: MR_P_BODY]
#2138303
08/22/16 12:42 AM
08/22/16 12:42 AM
Posts: 7,506 Az
Crizila
Az
I had mine clamped to the bed on my mill out at the end but I always used a drill motor Ya 1/2" drill is over 20 years old and on its 3rd set of brushes, but it operates at a nice slow 500RPM.
Fastest 300
[Re: 65 Hemi]
#2138500
08/22/16 12:37 PM
08/22/16 12:37 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I've used a Mittler bender and vertical mill notching fixture for over 20 years. With that being said, had a friend show me a video, https://youtu.be/mHBanmfn_CA a while back, and I thought, hmmm. So I tried it on the next cage. I'll use the notcher on a 90 degree fish mouth, but anything else, the chop saw. The notches are just as good and take 1/3 the time. See if you can tell which ones were done which way. ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_0770_zpsayo9yimp.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_0768_zpsgfzvda0m.jpg)
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
