Tubing Notcher??? #2137519
08/20/16 09:46 PM
08/20/16 09:46 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I am looking at buying a tubing Notcher that uses a end mill bit for roll cages. Has anyone ever used a vertical Mill as a tubing notcher? I am thinking I can kill two birds with one stone.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Tubing Notcher??? [Re: 65 Hemi] #2137539
08/20/16 10:37 PM
08/20/16 10:37 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I know this is not what you have asked but I have been in the steel fabrication game for over 30 years, done fair few cages and we notch or fishmouth our pipe by hand. Check out this site for your pipe wraps. http://metalgeek.com/static/cope_custom.pcgi
1963 Plymouth Max Wedge
1971 Barracuda
Re: Tubing Notcher??? [Re: 65 Hemi] #2137541
08/20/16 10:41 PM
08/20/16 10:41 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I used a pipe notcher from harbor freight and mounted it in a vice with a hole saw on my drill. Worked great!
Re: Tubing Notcher??? [Re: 65 Hemi] #2137556
08/20/16 11:00 PM
08/20/16 11:00 PM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
A vertical mill works way better than the end mill style notchers. I have done hundreds of roll cages with one, but you will still need to freehand some notches. I also prefer a hole saw notcher over the endmill type. It is faster and provides a cleaner cut.
Re: Tubing Notcher??? [Re: humpty] #2137564
08/20/16 11:09 PM
08/20/16 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used one of the cheap notchers for years....
but I rebuilt the shaft and put sealed bearings
in it.. the bushings wear out pretty quick even
being lubed... then I touch up the cuts with a
oscillating drum sander
wave
Re: Tubing Notcher??? [Re: 6pakdakota] #2137576
08/20/16 11:28 PM
08/20/16 11:28 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I was thinking the same thing and also a vertical mill can be picked up used for about half the price and can be used as a mill also. 👍🏻👍🏻👍🏻
Doug
MOPAR or NO CAR!!!
Re: Tubing Notcher??? [Re: ozymaxwedge] #2137580
08/20/16 11:31 PM
08/20/16 11:31 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks for the link
Doug
MOPAR or NO CAR!!!
Re: Tubing Notcher??? [Re: 65 Hemi] #2137584
08/20/16 11:40 PM
08/20/16 11:40 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Yes, I use a vertical mill for all my notching. I have a seriesII bridgeport with the larger collet set up. It works perfectly for notching and the auto feed saves holesaws/tooling.
Re: Tubing Notcher??? [Re: 65 Hemi] #2137623
08/21/16 12:29 AM
08/21/16 12:29 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By B1 Polara
Thanks for the link
up Here's one we done the other day, 37deg.
1971 Barracuda
Re: Tubing Notcher??? [Re: 65 Hemi] #2137651
08/21/16 01:38 AM
08/21/16 01:38 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have a Woodward Fab one, solid and reliable. Use plenty of oil and drill on low.
Mopar to the bone!!!
Re: Tubing Notcher??? [Re: 65 Hemi] #2137836
08/21/16 12:06 PM
08/21/16 12:06 PM
Az
Crizila Offline
Crizila  Offline
Az
Proform.
Fastest 300
Re: Tubing Notcher??? [Re: Crizila] #2137846
08/21/16 12:17 PM
08/21/16 12:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had mine clamped to the bed on my mill out at
the end but I always used a drill motor
wave
Re: Tubing Notcher??? [Re: 72Swinger] #2137884
08/21/16 12:55 PM
08/21/16 12:55 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I was always told to never use oil. Soapy water to keep it cool?
I'm I doing this wrong?
Matt
Re: Tubing Notcher??? [Re: MattW] #2137918
08/21/16 01:34 PM
08/21/16 01:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Matt
I used to use oil on my hole saw notcher. Makes a mess that has to be cleaned inside and out before welding. I've been using it dry for a while now. I see no difference in saw life. Feed and drill speed are what you have to pay attention to for saw life and not making it too hot.
As far as the OP's question, I would think an indexable vise for tubing and the correct bit would be all that is needed to notch tubing on a mill. Tooling is obviously more expensive and I'd be interested to know how long the cutters last when cutting CM.
Mittler and Baileigh make nice machines, but I don't know how you justify the cost for one of those in the majority of shops. Have to be turning out a lot of cars. A GOOD holesaw notcher (one that's not flimsy and waving in the breeze with a long piece of tubing in it) makes just as nice of a notch and can typically cut a notch closer to a bend than the machines with the larger vises. JD2 is making the nicest holesaw type notchers that I see for sale now.
Re: Tubing Notcher??? [Re: 65 Hemi] #2138214
08/21/16 10:07 PM
08/21/16 10:07 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Once you use a mill you will never want to use a notcher. I can use the same single holesaw on chromoly tubing over and over and over. I would estimate a 1 5/8 holesaw gets me around 30 perfect cuts before I switch it out. No coolant/lube.
You would be way farther ahead buying a used mill than a new notcher.
Re: Tubing Notcher??? [Re: 65 Hemi] #2138288
08/21/16 11:17 PM
08/21/16 11:17 PM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
I used to use mac holesaws with a joint jigger notcher. With cut ease wax I could get about 80 cuts on cm and the mac guy would warranty them for me if I broke any teeth.
Re: Tubing Notcher??? [Re: MR_P_BODY] #2138303
08/21/16 11:42 PM
08/21/16 11:42 PM
Az
Crizila Offline
Crizila  Offline
Az
wave
Ya 1/2" drill is over 20 years old and on its 3rd set of brushes, but it operates at a nice slow 500RPM.
Fastest 300
Re: Tubing Notcher??? [Re: 65 Hemi] #2138316
08/22/16 12:08 AM
08/22/16 12:08 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
A friend has a mill cutter 1.5/8 diameter, spiral type. The same bit used in those hi dollar machines. This he chucks in his lathe, then he made a pipe holder that sets where the tool bits holder is. He sets the angle, then feeds into the cutter, makes very nice precision cuts. Only needing de-blurring the edges. The bit cost around two hundred but very cost effective. As soon as I get my lathe moved to my new shop I'm setting it up the same way.
Re: Tubing Notcher??? [Re: 65 Hemi] #2138351
08/22/16 01:38 AM
08/22/16 01:38 AM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
I've used a porta-band for over 40 years for the notching I've done... but most of the stuff I do is one-off pieces where speed isn't a factor. The Horrible Freight notchers can be modded to work pretty good but you need a good USA made hole saw for them to last.
https://www.youtube.com/watch?v=Ty915Z0GrJo
Re: Tubing Notcher??? [Re: 65 Hemi] #2138500
08/22/16 11:37 AM
08/22/16 11:37 AM
CJD AUTOMOTIVE Offline
I've used a Mittler bender and vertical mill notching fixture for over 20 years. With that being said, had a friend show me a video, https://youtu.be/mHBanmfn_CA a while back, and I thought, hmmm. So I tried it on the next cage. I'll use the notcher on a 90 degree fish mouth, but anything else, the chop saw. The notches are just as good and take 1/3 the time.
See if you can tell which ones were done which way.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
