One of none 82 D-250 #2138365
08/22/16 03:51 AM
08/22/16 03:51 AM
Mi,U.S.A.
mike s Offline OP
mike s  Offline OP
Mi,U.S.A.
Not too difficult. Minor exh,shift linkage and kick down issues.
Leave the gun.......take the Cannoli's....Mike
Re: One of none 82 D-250 [Re: mike s] #2138377
08/22/16 07:22 AM
08/22/16 07:22 AM
places
79powerwagon Offline
places
Probably a big step up from the factory 318! smile
Re: One of none 82 D-250 [Re: 79powerwagon] #2138420
08/22/16 10:49 AM
08/22/16 10:49 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
A Poly? eek
Something a little different.
I like it. up
Any more info?
I have mechanical Aptitude.
I can screw up anything.
Re: One of none 82 D-250 [Re: bboogieart] #2138662
08/22/16 03:59 PM
08/22/16 03:59 PM
Mi,U.S.A.
mike s Offline OP
mike s  Offline OP
Mi,U.S.A.
Heads were updated to hardened exh seats, electronic mopar perf dist and engine is .030 over size. Nice 80-100 h.p. increase over the original engine. At least 50 ft lbs increase in torque also (340@ only 2400).It would have been even easier with poly truck exh manifolds or a set of center dump shorties. Stock mounts worked just needed to move the driver side to behind the block mounting lugs.A bit of clearance was added to clear shift linkage (not needed w/ center dump exh). A aftermarket kick down cable would have been a nice addition.Converted over the alt to 70's style.Used 66 poly steering pump with poly ends at pump and 82 hose at box.(Welded on poly end).Used the poly mount for the throttle cable also. Thats about it.
Of course the lower bolt on the drivers side( the large one that goes in from the front) from the block to trans will not line up but you can modify the 82 side strut that goes from block to trans if you think you need it.
Re: One of none 82 D-250 [Re: mike s] #2140218
08/24/16 10:08 PM
08/24/16 10:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
WOW!
Yours looks great, and sounds like a winning package.
I wouldn't change a thing, but thought I'd throw this up here.
There is some aftermarket stuff being made for the poly now.
Not cheap though.
http://www.performance-mopar.com/index.php/1-poly
