water pump knock #2138102
08/21/16 07:53 PM
08/21/16 07:53 PM
S.e. lower MIch..
66droptop Offline OP
S.e. lower MIch..
318 stock,started making a small rattling sound recently now it sounds like a knock Does not get faster with engine rpm.Took the Alt., water pump belt off and no noise.Could the water pump a knocking noise.Used a long screwdriver as a stethascope and could here no knock anywhere.Am a little confused....
Re: water pump knock [Re: 66droptop] #2138128
08/21/16 08:32 PM
08/21/16 08:32 PM
got another alt you could sub for a quick test to try & pin it down. agreed, I'd sure think a noise from either one of them would be RPM dependent, especially the pump. EDIT first unplug a field wire on the alt & see if it gets quiet
Re: water pump knock [Re: RapidRobert] #2138158
08/21/16 09:29 PM
08/21/16 09:29 PM
S.e. lower MIch..
S.e. lower MIch..
I took the alt.to a local parts store to test.While testing I heard no abnormal sound.It tested just fine...
Re: water pump knock [Re: 66droptop] #2138163
08/21/16 09:38 PM
08/21/16 09:38 PM
S.e. lower MIch..
S.e. lower MIch..
Is the field wire the one you can just pull off.The connector was loosly fitted so I put a new end on and the noise is more eratic but is still there.
Re: water pump knock [Re: 66droptop] #2138196
08/21/16 10:46 PM
08/21/16 10:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've heard that before, and the water pump/fan shaft would be loose if wiggled. It was the bearing area eating itself up.
I once worked for a guy that had an old Ford truck, same racket that got pretty loud. He wouldn't fix it. When the water pump came apart, the noise stopped. But so did the cooling, not least of which was from the fan hitting the radiator.
Re: water pump knock [Re: 66droptop] #2138219
08/21/16 11:10 PM
08/21/16 11:10 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
if the sound doesnt change w engine rpm its not the engine or anything bolted to it
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: water pump knock [Re: 66droptop] #2138224
08/21/16 11:15 PM
08/21/16 11:15 PM
sometimes an alt electrical malfunction of a certain type (diode?) can make a squeal usually high pitched like a siren which certainly ain't the case here but it would take 3 seconds to pull it to elim that & swapping the alt would be easier than swapping a pump but the alt would do it at the parts house the same way (be making the noise) so but now the pump is looking guilty tho I would think the noise would increase with RPM
Re: water pump knock [Re: RapidRobert] #2138268
08/21/16 11:52 PM
08/21/16 11:52 PM
IN
ahy Offline
ahy  Offline
IN
Or the fan clutch could be failing or even loose. With the belt off is there any unusual slop in the WP shaft or fan/clutch/spacer?
Re: water pump knock [Re: 66droptop] #2138378
08/22/16 07:39 AM
08/22/16 07:39 AM
S.e. lower MIch..
S.e. lower MIch..
Just a little play.It does not seem to excessive,but it could be enough..
