Hi - I cannot figure out why my 440 cranks over very slow only when it's warmed-up. I heard about starter heat soak so I wrapped the headers, but it made no difference. Here's some more of the particulars: 1970 Barracuda, 440-6V, AT, MSD billet dist. w/mech adv., MSD 6A box, MSD coil, new mini style starter from DB Electrical on ebay, Hooker headers wrapped and sealed, battery in trunk with 00 gauge + cable, standard + battery cable used for solenoid to starter, timing set at about 15 degrees of initial advance, 100 amp alternator.
I saw on another web forum that wiring in a Ford starter relay solves the problem - anybody ever try this? I'm going to make sure that my battery is good and double check my initial advance. I'm also going to swap out the coil after warming up the motor to rule out a bad coil. Could I have wired something wrong (like the ballast resistor) that could be causing this?
It's really driving me crazy - any suggestions would be greatly appreciated!
Thanks,
Greg
