Re: Welders in the house? Disaster strikes!
[Re: gdonovan]
#2136216
08/18/16 10:33 PM
08/18/16 10:33 PM
Posts: 76 georgia
intenseneon
georgia
I had a bud weld the crack on my trans case, still holding up after 5 years, he heated it up to burn out the impurities.
69 Dart
[Re: gdonovan]
#2136217
08/18/16 10:33 PM
08/18/16 10:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've migged alum... V it out and preheat it.. I normally do both sides.. make sure its clean
[Re: gdonovan]
#2136229
08/18/16 10:50 PM
08/18/16 10:50 PM
Posts: 11,654 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Clean, clean, clean. Do NOT use brakekleen.
[Re: gdonovan]
#2136230
08/18/16 10:50 PM
08/18/16 10:50 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Drill the end of the crack and run it.
Have a great day Iowan
"obsolete is neat"
[Re: CMcAllister]
#2136240
08/18/16 11:00 PM
08/18/16 11:00 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Clean, clean, clean. Do NOT use brakekleen. Or it could be the last welding you ever do. Great meeting you the other day Cole and boy did I hit rain on the way home. See you next week. Thanks
[Re: MR_P_BODY]
#2136242
08/18/16 11:01 PM
08/18/16 11:01 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I'd migged alum... V it out and preheat it.. I normally do both sides.. make sure its clean Doing both sides not a problem and the crack is all the way through. Trying hard not to get mad at the kid, don't want to discourage him.
"I think its got a hemi"
[Re: gdonovan]
#2136264
08/18/16 11:19 PM
08/18/16 11:19 PM
Posts: 22,697 Bitopia
jcc
Bitopia
I'd migged alum... V it out and preheat it.. I normally do both sides.. make sure its clean Doing both sides not a problem and the crack is all the way through. Trying hard not to get mad at the kid, don't want to discourage him. I bet he feels worse then you do. I remember when I was 8, I was washing my dad's car with the very abrasive "Comet" clreaner, couldn't understand why the more I scrubbed, the browner It got (primer) . Might be a good time to share with him something yiu did as a kid that shows we all do things we are embarrassed about, but life goes on. Its a life lesson that can be fixed. Doesn't look like a highly stressed location, but the pic doesn't show much. I would not mig the crack, tig for me. If it gets vee'd to a point, from both sides, the crack will automatically be clean, regardless, don't get the crack wet without rapidly drying the crack, Drilling a hole achieves little if you are welding it before any use. The brake cleaner suggestions are spot on.
[Re: gdonovan]
#2136277
08/18/16 11:31 PM
08/18/16 11:31 PM
MR_P_BODY
I had the tail shaft fall off my bench when I was rebuilding the trans... broke a bolt ear off... I V it out good and clamped a plate to it and welded it back on... still running fine... I did have to hit it on the belt sander to smooth it out.. no leaks I tigged mine... with 1/8 rod for filler
[Re: gdonovan]
#2136307
08/19/16 12:01 AM
08/19/16 12:01 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Easy fix, as the guys have said clean. I would fully vee out, pre heat, weld and then vee out (back gouge) other side and weld again. Get the young gun to watch the repair.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: jcc]
#2136309
08/19/16 12:02 AM
08/19/16 12:02 AM
Posts: 4,087 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I'd migged alum... V it out and preheat it.. I normally do both sides.. make sure its clean Doing both sides not a problem and the crack is all the way through. Trying hard not to get mad at the kid, don't want to discourage him. I bet he feels worse then you do. I remember when I was 8, I was washing my dad's car with the very abrasive "Comet" clreaner, couldn't understand why the more I scrubbed, the browner It got (primer) . Might be a good time to share with him something yiu did as a kid that shows we all do things we are embarrassed about, but life goes on. Its a life lesson that can be fixed. Doesn't look like a highly stressed location, but the pic doesn't show much. I would not mig the crack, tig for me. If it gets vee'd to a point, from both sides, the crack will automatically be clean, regardless, don't get the crack wet without rapidly drying the crack, Drilling a hole achieves little if you are welding it before any use. The brake cleaner suggestions are spot on. I agree the kid prob feels worse than you realize. That can be fixed no problem.
[Re: gdonovan]
#2136331
08/19/16 12:35 AM
08/19/16 12:35 AM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
This cannot be stressed enough. But personally, I'd drill the holes at each end, V it out a bit and leave it at that - no cleaning !! Why? Because its a fresh crack and should be clean. Trying to clean it could just make it worse. If its worth anything, why not take it to someone with a tig and have it done right. Mig welding aluminum is fine for high volume production but has no place where quality and durabilty are needed. And a good tig welder can be set up to "clean".
[Re: Goat330]
#2136440
08/19/16 07:10 AM
08/19/16 07:10 AM
gdonovan
Oakdale CT
pay someone to Tig weld it, chances are your little home mig machine doesn't have enough amps to get good penetration. Not a home rig, work unit with enough amps to smoke holes in 1/2 plate. When it arrived we experimented with various settings to see how far we could push before stuff started getting out of hand. Impressive machine.
[Re: racerx]
#2136674
08/19/16 03:30 PM
08/19/16 03:30 PM
jcc
Bitopia
The crack itself does not determine the v groove, the thickness of the part at the crack line does, and a 45deg is a good start. Both sides only if the part has decent thickness IMO
