Re: 5.7 new hemi to il school sb conversion
[Re: rumblebee4232]
#2136864
08/19/16 09:44 PM
08/19/16 09:44 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Just tryin to be difficult ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) and deviate from norm It would be cool . I just need a steering wheel and turn signals ! And 12 v for spark I doubt shumaker or anyone thought of the backwards swap.
[Re: sogtx]
#2136935
08/19/16 11:25 PM
08/19/16 11:25 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Everything runs thru the computer.
Electric windows? computer
radio? computer
rear defrost? computer
etc. Pretty sure the dome light - computer.
[Re: DaytonaTurbo]
#2137036
08/20/16 01:29 AM
08/20/16 01:29 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Lets go the other direction. You would need to ADD the electronics to the LA engine. Would probably be easier to add the injectors, a crank trigger, coil packs, O2's, etc to the LA and get the computer tuned than to gut the newer Challenger electronics. It would be easier to simply install another Gen III, but that wasn't the question
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: savoy64]
#2137209
08/20/16 01:13 PM
08/20/16 01:13 PM
Evil Spirit
Newport, Mi
on a 2000 ram 5.2 the cam sensor is the distributor and the crank sensor is the flywheel----on the cummins setups the crank sensor is simulated with notches in the crank damper----not looking like brain surgery yet---and more surprising yet the guys found the 5.2 computer has the same transmission shift points as the cummins computer so they didnt even sweat changing those out..... Not sure how relevant putting a Cummins - even an electronic 24v - into a 2000ish truck really relates to the original post of putting a LA engine in place of a Gen III Hemi. Both the Gen III and the Chally have far more electronics to deal with - not only the engine controls, but also all the other accessories that are controlled by the computer. And I would really find it surprising that a stock Cummins computer tune shifts them at the 4800 +/- rpm (WOT) that a typical 5.2 shifts at. FYI a 2002 Cummins factory ECM governed RPM is 3200.
[Re: savoy64]
#2137236
08/20/16 02:09 PM
08/20/16 02:09 PM
Evil Spirit
Newport, Mi
i mention it because the 4bt has no electronics at all----and the builds pitting them against an RE tranny are there for you to read if you like (i havent done one)yes the computers have all those redundant systems built in like idle compensators with the AC on and others---but even with that i have a friend that has plugged those new motors into old cars by cleaning out those pesky programs---and there is a legion of guys here doing the same thing with gen III into old cudas and such----so yeah----i think it can be done---and sorry for being the only cheerleader here.... New motors into old cars is a totally different scenario. You only need to deal with the engine/transmission controls and you don't have to worry about all the accessories the ECM controls. IMO putting an LA into a Gem III car could run into a lot of accessories dead from the ECM not seeing the proper inputs from the engine. IMO the key would be to make the ECM think it is still running the Gen III engine by adding the engine controls to the LA engine - the injectors, coil packs, crank triggers, IAC motors, etc. Not trying to buzzkill here - I think it would be a neat PROJECT - but a complicated and probably an expensive one. Simply getting the LA ENGINE to run is easy - keeping all the functions of the newer Chally package is the issue. If I was going to do this, I would probably start with a stolen recovery car that had been stripped of the engine and electronics. Probably be an easier platform to install fresh from scratch than to convert. IMO I wouldn't do this to a functioning car that simply needed a new engine. Good luck to the O/P on whatever path he chooses. At least he didn't mention an LS swap!
[Re: Supercuda]
#2137280
08/20/16 03:03 PM
08/20/16 03:03 PM
DaytonaTurbo
Manitoba, Canada
radio? computer
etc. Pretty sure the dome light - computer. Ditto. In the late 80's and into the 90's most mopars started getting body control modules. These took over functions like power locks, lighting, windshield wipers, gauges etc. Now the BCM communicates much more with the engine computer and also controls your abs, traction control, power windows and all your interior goodies. You would either have to trick the PCM into thinking the engine is running, which even if you can get the cam and crank sensors to work, you'll never hook up the drive by wire throttle. Without the engine working properly, there goes your transmission controls. At that point you might as well gut every wire out of the car and install an aftermarket hot rod type wiring harness. I bet the expense and hassle would exceed that of rebuilding the 5.7.
[Re: sogtx]
#2139933
08/24/16 02:52 PM
08/24/16 02:52 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You will essentially need to rewire the entire car. Windows, locks, ignition, lights, switches, and most everything else with a wire attached.
