Advice on Choosing a Musclecar Oil #2131974
08/13/16 02:50 PM
08/13/16 02:50 PM
Central Texas
b_body_fan Offline OP
Central Texas
Are there any readily available motor oils designed specifically for older high performance musclecars? When I say readily available, I mean something that is found at any local auto parts stores. What recommendation does anyone have for products bought at the local auto parts store and through mail order.
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132018
08/13/16 03:51 PM
08/13/16 03:51 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
As far as I know the only readily available oil with adequate ZDDP is valvoline VR-1. Most stores also carry additives that can be combined with newer oils to raise the ZDDP levels
popcorn
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132044
08/13/16 04:16 PM
08/13/16 04:16 PM
BDW Offline
BDW  Offline
I use the Lucas break in additive, $15 at Advanced Auto, and any conventional oil.
It's enough for 3 oil changes. I can't justify paying $7-10 a quart for "racing" oil.
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132055
08/13/16 04:27 PM
08/13/16 04:27 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
All the muscle / racing oils are way over priced
That is why I switched to 15-40 Rotella Diesel Oil in all my flat tappet cars. Still have what is needed to lube up the cam.
Cheap and by the gallon
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132056
08/13/16 04:30 PM
08/13/16 04:30 PM
tucson az
frank Offline
frank  Offline
tucson az
Brad Penn is what I put in my cars. Any performance/hot rod shop should carry it. Its on the shelf where I live. You don't need to add anything to this oil; just pour it in.
Re: Advice on Choosing a Musclecar Oil [Re: moparts] #2132071
08/13/16 04:52 PM
08/13/16 04:52 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
FYI,
Rumor had it a few years back that again due to emissions etc. on Diesels the ZDDP content in Rotella was being reduced. You may want to check into the validity of that claim with Rotella. beer
Re: Advice on Choosing a Musclecar Oil [Re: TJP] #2132091
08/13/16 05:22 PM
08/13/16 05:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Updated in 2016:
https://en.wikipedia.org/wiki/Shell_Rotella_T
I use it in a motor with the cam already well broken in but I wouldn't use it for break-in without an additive.
Re: Advice on Choosing a Musclecar Oil [Re: frank] #2132098
08/13/16 05:42 PM
08/13/16 05:42 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yep I use Brad Penn 20W 50 $7 a quart but does the job without worrying.
Years back I used Rottella but never liked how it looked when doing a change. Isn't as good as it used to be for our car's.
Ron
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132125
08/13/16 06:31 PM
08/13/16 06:31 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Any oil with an API rating of 'SJ' or lower is suitable in older engines.
Re: Advice on Choosing a Musclecar Oil [Re: RJS] #2132131
08/13/16 06:42 PM
08/13/16 06:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Ron
And no additive needed !
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132160
08/13/16 07:24 PM
08/13/16 07:24 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
no reason brad penn should cost that much
5549 post on old board
Re: Advice on Choosing a Musclecar Oil [Re: John_Kunkel] #2132161
08/13/16 07:25 PM
08/13/16 07:25 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Originally Posted By John_Kunkel
Updated in 2016:
Yes Brake in with EOS, then reg Rotella after that
Re: Advice on Choosing a Musclecar Oil [Re: moparts] #2132247
08/13/16 09:48 PM
08/13/16 09:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I look at it this way, how often do you change the oil in your hotrod? Most of us it's once a year so what's $50 for something as important as good oil in a flat tappet cam engine shruggy
I use Brad Penn for my engine on the advice of of some knowledgeable engine builders.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Advice on Choosing a Musclecar Oil [Re: fourgearsavoy] #2132256
08/13/16 09:55 PM
08/13/16 09:55 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Brad Penn here too.
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132622
08/14/16 01:17 PM
08/14/16 01:17 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
VR-1 is easy to find, and more than good enough for the muscle car that putts around under 4K RPM for most of its outings.
Re: Advice on Choosing a Musclecar Oil [Re: fourgearsavoy] #2132638
08/14/16 01:37 PM
08/14/16 01:37 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Gus beer
Good info here. My engine machinist also races a SC dragster. His oil recommendation for street cars is Joe Gibbs or Brad Penn. This is your choice. How soon do you want to repair your engine that is otherwise fine?
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132639
08/14/16 01:39 PM
08/14/16 01:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Royal Purple oils/filters
Re: Advice on Choosing a Musclecar Oil [Re: b_body_fan] #2132688
08/14/16 03:02 PM
08/14/16 03:02 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Rotello 15/40 with a little ZDDP added
Abe Lincoln
Re: Advice on Choosing a Musclecar Oil [Re: dart4forte] #2132775
08/14/16 05:40 PM
08/14/16 05:40 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I used to use "standard oils and additives. Now I just use Brad Penn and don't worry about it. It's not like I'm changing the oil every month...
Re: Advice on Choosing a Musclecar Oil [Re: Ramrod39] #2132920
08/14/16 08:47 PM
08/14/16 08:47 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Kendall 10-40 and a little bit of GM EOS. GM EOS is super expensive here. I think I spent almost $45.00 for the last two bottles I bough this spring????
Used to use Valvoline standard oil in the same viscosity, but the Kendall holds pressure a tad better on hot days. Auto parts stores don't stock Kendall so I have to get it at a fleet retailer by the box. Still way cheaper than the $5.00+ per bottle oil at the parts stores. Valvoline is still nice oil and I wouldn't hesitate to use it again.
I don't use synthetic in anything that sits for extended periods as the crank grinder guy I use says it's so slippery it doesn't cling to anything so you can end up with a dry cam and lifters on vehicles that don't get used frequently.
