Hose to big for fuel filter. Video incl. #2132508
08/14/16 06:43 AM
08/14/16 06:43 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I've put on a new fuel pump and fuel filter. As can be seen in the video the hose from the filter to the carb is too big. I'm showing the hose bit that came with the filter in the beginning of the video. What would be best here, get a smaller hose (will it fit the carb) or put the bit that came with the filter on and use some sort of connector?
http://sendvid.com/cffkqiv2
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Hose to big for fuel filter. Video incl. [Re: xyxxjx] #2132512
08/14/16 07:42 AM
08/14/16 07:42 AM
None
71rm23 Offline
71rm23  Offline
None
Uh, what video?
Re: Hose to big for fuel filter. Video incl. [Re: 71rm23] #2132517
08/14/16 09:03 AM
08/14/16 09:03 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Originally Posted By 71rm23
Uh, what video?
Crap.. forgot link. drumhit it's up now.
Re: Hose to big for fuel filter. Video incl. [Re: xyxxjx] #2132526
08/14/16 09:47 AM
08/14/16 09:47 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
go get the right size filter? that inlet looks pretty small. the little piece that came with the filter is for going from filter to hard line.
you might be able to cut a 1/2 inch off your existing line to get a better fit. the rubber lines kinda stretch out and conform to what they were on.
Re: Hose to big for fuel filter. Video incl. [Re: mikemee1331] #2132528
08/14/16 09:54 AM
08/14/16 09:54 AM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
First check if the hoses are all correct... 3/8 or 5/16.... which is spec for your ride??... is there a mismatch.... then .. is your new fuel pump output threaded so you can choose a barb to be conducive to your line size up to the carb,,, from "barb to carb" drumhit should be all one size.... the difference might not seem much (5/16 to 3/8) but its like the difference between your honeymoon night and the 20th anniversary!!...... shruggy
Re: Hose to big for fuel filter. Video incl. [Re: xyxxjx] #2132563
08/14/16 11:41 AM
08/14/16 11:41 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Your trying to install a 3/8" hose onto a 5/16" fuel filter
Just buy some 5/16" fuel hose to run from filter to carb
Let's see your inlet barb into carb for size and fit
Anyways
Honeymoon versus 20 years - I hope I can make it to twenty years let alone have
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Hose to big for fuel filter. Video incl. [Re: xyxxjx] #2132831
08/14/16 07:10 PM
08/14/16 07:10 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Wonder what the equivalent tube size would be for the 40th anniversary, maybe radiator hose. drumhit drumhit
Re: Hose to big for fuel filter. Video incl. [Re: xyxxjx] #2132847
08/14/16 07:33 PM
08/14/16 07:33 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Here is a picture of the old and the new filter. The old filter is slightly bigger, not by much though, maybe 1/8". I've tried cutting a bit more off the end of the hose and now there is resistance when I put it on, not super tight like the others but snug enough so that I can lift it up by the hose. Would this not be good enough if i tighten the clamp extra snug?
https://drive.google.com/file/d/0B8IgeG75F_MIbjNTc2NWQzhUaWc/view?usp=drivesdk
Here's the filter type
https://drive.google.com/file/d/0B8IgeG75F_MISVUzSHgyWVlnUUk/view?usp=drivesdk
