Re: 70 Roadrunner 383 Holley 4160 (3310-8) base gasket
[Re: fisher972002]
#2132616
08/14/16 01:12 PM
08/14/16 01:12 PM
Posts: 3,527 Lansing, MI
70gtx440dana
Lansing, MI
The one I have always used on my 70 383 is like this one. It is thick with compression limiters at each bolt hole:
http://www.ebay.com/itm/Holley-108-18-5-16-Base-Gasket-for-Model-4010-4150-4160-/152016900260?hash=item2364e9d0a4:g:teoAAOSw5HJXKvrr&vxp=mtr
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: fisher972002]
#2134053
08/16/16 01:26 AM
08/16/16 01:26 AM
70gtx440dana
Lansing, MI
Here is the exact gasket i use on mine.......
http://www.ebay.com/itm/Felpro-Carburetor-Mounting-Gasket-New-Town-and-Country-Fury-Chrysler-60123-/121575254374?fits=Year%3A1970%7CMake%3ADodge%7CModel%3ACharger&hash=item1c4e732966:g:NY8AAOSwARZXp1FV&vxp=mtr
[Re: 70gtx440dana]
#2134284
08/16/16 12:53 PM
08/16/16 12:53 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Thankyou as well!! Will order... I had no idea...
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: fisher972002]
#2198571
11/18/16 05:41 PM
11/18/16 05:41 PM
Posts: 82 Des Moines, Iowa
fisher972002
Des Moines, Iowa
All,
I wanted to circle back on this thread and let you know that I fixed my issue once and for all...
When we replaced the accelerator pump, the original carb had 2 thinner 4 barrel gaskets. The inside plus sign was worn away, or eaten away. I replaced the carb gaskets with the Holley 108-18. When I put this on, we noticed immediately this strange whistling sound slightly above idle.. I've driven the car for a few months like that. It had an off-idle stumble when the whistle sound happened, then when the whistle stopped, it ran fine...
I was thinking, let's replace the gasket with the same style as I took off. So I bought a Holley Carb Gasket Base Gasket Part # 108-58, where it has the outlines of the 4 barrels. - factory iron intake
Wow, the car runs much better. It has smoother transition from idle to mid throttle and the whistle is gone. I think the whistling was air moving through the carb and or hitting that gasket that looks like a gasket for a dual plane intake ?
Happy Motoring.
