Wheel bearing grease... #2131334
08/12/16 06:58 PM
08/12/16 06:58 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Anyone want to make a recommendation? I have a container of "Multipurpose Grease" that does say for wheel bearings on the label, but the stuff seems very light. Just like a can of Vaseline.
Re: Wheel bearing grease... [Re: rarefish] #2131350
08/12/16 07:11 PM
08/12/16 07:11 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use the blonde colored wheel bearing grease made by Quaker State or Castrol. It works very well on wheel bearings.
Nautilus Racing-
Re: Wheel bearing grease... [Re: rarefish] #2131357
08/12/16 07:17 PM
08/12/16 07:17 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Years ago I had some of the really old stringy wheel bearing grease.. It was about the consistency of Crisco...
My mechanic friend, who I have a lot of respect for, was just crackin up when he saw I was going to use it to pack some wheel bearings.. Told me it was really old school and the more modern greases were much better....
Re: Wheel bearing grease... [Re: minivan] #2131369
08/12/16 07:28 PM
08/12/16 07:28 PM
Missouri
Big_E Offline
Big_E  Offline
Missouri
I saw where Eberg of Mopar Action recommended Mopar Grease 4318064. I've never tried it.
Re: Wheel bearing grease... [Re: rarefish] #2131379
08/12/16 07:39 PM
08/12/16 07:39 PM
Andrewh Offline
Andrewh  Offline
I have used the mobile one red grease for many years on wheel bearings and ball joints.
Re: Wheel bearing grease... [Re: Chris2581] #2131449
08/12/16 08:56 PM
08/12/16 08:56 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
same here
Re: Wheel bearing grease... [Re: Big_E] #2131487
08/12/16 09:36 PM
08/12/16 09:36 PM
I think that is the green grease. I got a tube just from his recommendation. way back there was something about "long fiber' grease is what you want. I never did grasp what that was about
Re: Wheel bearing grease... [Re: RapidRobert] #2131595
08/12/16 11:11 PM
08/12/16 11:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Minivan mentioned it up above. my grandfather had that stuff back in the day.
Re: Wheel bearing grease... [Re: mikemee1331] #2131611
08/12/16 11:29 PM
08/12/16 11:29 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
In my 4th current Tacoma PU I have owned since new, this one with 378K miles, I decided today to change out the original front discs. That meant removing the hubs/bearings, which have never been serviced. The yellow OEM grease, still looked pretty good, and I figured if the bearings were of good enough quality to show zero signs of wear after all these miles, I couldn't figure out why to replace them with today's new junk. Bottom line, that grease must be pretty decent, whatever it is.
Re: Wheel bearing grease... [Re: jcc] #2131666
08/13/16 12:42 AM
08/13/16 12:42 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
I found the other Eberg article that talked about the long fibre grease. Seems it referred to using it on just the tie rod ends.
Re: Wheel bearing grease... [Re: Big_E] #2131728
08/13/16 02:04 AM
08/13/16 02:04 AM
I'd have to check but I think the middle tube with the blue lettering is the green grease I got & the dealer sold me (1) tube (he might had ten in stock at one time)
Re: Wheel bearing grease... [Re: RapidRobert] #2131734
08/13/16 02:20 AM
08/13/16 02:20 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The Mopar high temp wheel bearing grease was #4318064. Now if you ask for that they'll sell you 05083150AA instead. I have a black tube of the old with a little bit left in it, and a silver tube of stuff with the new part # and they look the same (dark green).
The long fiber multi-mileage lube is for suspension, steering, and u-joints.
Re: Wheel bearing grease... [Re: Neil] #2131745
08/13/16 02:40 AM
08/13/16 02:40 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Been using the Valvoline hi temp multi purpose. Just bought a new tub of synthetic.
With the modern sealed hub bearings, don't have a big need to repack anymore.
Re: Wheel bearing grease... [Re: Neil] #2131748
08/13/16 02:45 AM
08/13/16 02:45 AM
Neil just to confirm, all (3) of the tubes pictured are the long fiber good stuff?
Re: Wheel bearing grease... [Re: RapidRobert] #2132060
08/13/16 04:35 PM
08/13/16 04:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
They appear to be the same. I own a silver tube like the one in the middle, and if you go to a Dodge, Chrysler, Jeep dealership and ask for the long fiber grease that's what you'll get.
The ones on the left and right I have not seen. I suppose they are older and the labels are just different???
I have always been able to buy single tubes of both the wheel bearing and MM lube. I know the Mopar Action article says you have to buy a case, but my local Dodge dealership has been fine with selling me a single tube, or whatever number of tubes as I ask for individually.
Re: Wheel bearing grease... [Re: Neil] #2132234
08/13/16 09:22 PM
08/13/16 09:22 PM
thank you Neil, I have the middle tube & just wanted to confirm it is the good stuff. I'm almost positive it was green grease & was the part # Eberg said to get
Re: Wheel bearing grease... [Re: rarefish] #2133486
08/15/16 01:21 PM
08/15/16 01:21 PM
W
Wagonman1967 Offline
W
When I apprenticed for an old Italian guy in 72 he called it horse grease. Said it was made from horses IDK. We had a 20 gallon bucket full and used it on everything,that was some sticky stinky stringy stuff. Made by Gulf IIRC.
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Wheel bearing grease... [Re: rarefish] #2133845
08/15/16 09:02 PM
08/15/16 09:02 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I've always been a fan of Pennzoil 707L. Red lithium high temp.
Re: Wheel bearing grease... [Re: rarefish] #2133870
08/15/16 09:50 PM
08/15/16 09:50 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I like the Mercedes Benz wheel bearing grease its also green & was free when I worked for MB.
Re: Wheel bearing grease... [Re: rarefish] #2133912
08/15/16 10:46 PM
08/15/16 10:46 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
There are different grades of Grease and should not noted on the label somewhere. I can't remember the designations, but it is something like GL. Of course you want the higher rating you can afford.
