Part # for a wiper motor?
#1534278
11/17/13 05:17 AM
11/17/13 05:17 AM
Posts: 3,344 Central TX
roe
Central TX
Does anyone know the part3 for a 2speed wiper motor for a 71 B body? It is year and body style specific.
Thanks roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Part # for a wiper motor?
[Re: moparfan53]
#1534282
11/17/13 09:25 PM
11/17/13 09:25 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Some of the 2926929 P/N motors had the part number stamped in the ground strap. I have some originals I could restore for you. If you go looking for one be sure it only has 1 brass terminal as that is a reversing motor for 70-71 E-body and 71 B-body
NS1AAR
[Re: roe]
#2132157
08/13/16 07:19 PM
08/13/16 07:19 PM
Posts: 25 VT
Mike Roberge
VT
Can I use a readily available 2 speed ’72 Charger wiper motor to replace my near impossible to find 2 speed ’71 Charger wiper motor? *I realize I could get my ’71 2 speed motor restored/repaired, but all I’m looking for is a basic parts store price and quality
*The ’72 wiper motor looks the same as my ‘71, but I am aware that the ’71 B body uses wiper crank/pin arm 2822290, whereas the ’72 Charger uses wiper crank/pin arm 3431553
When I look at pictures online of these two crank arms, they look virtually the same? So my question is: will I be able to use/mount my 2822290 crank arm on the ’72 motor?
Michael Roberge
'71 Charger R/T
440 4bbl, 500HP/500Ftlb
Best ET: 11.590 120MPH
[Re: roe]
#2153581
09/13/16 11:16 AM
09/13/16 11:16 AM
Posts: 25 VT
Mike Roberge
VT
Update for ’70 & ‘71 E-body, and ’71 B-body 2-Speed Wiper motor replacement:
I have learned that the readily available/affordable parts store ’72 Charger(’73 Challenger) wiper motor is a direct bolt in, and the ’71 linkage crank arm will bolt up, but is a bit loose due to the ’72 motor has a smaller shaft.
For me, this resulted in sloppy wiper action: The wipers wouldn’t cover as much windshield, and the would not park properly(wouldn’t hide away completely) – due to the slop. Also, the ’72 motor shaft Parks/stops in a slightly different position (*this probably also attributes to not parking in the correct position).
Upon further investigation I found out the ’72 Crank arm motor shaft rectangular cutout is at a different angle than the ’71 Crank arm. So, I purchased a ’72 crank arm(pt#3431553) on eBay to go on my ’72 motor. It fits perfectly w/no slop. Now my wipers work perfectly and park perfectly, - like brand new!
Michael Roberge
'71 Charger R/T
