Re: Remote rad option and opinions street/strip car [Re: moparx] #2133566
08/15/16 03:15 PM
08/15/16 03:15 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
If you don't have the room in your current car, then buy one that has the room. The first car that comes to my mind is a '72 to '74 Dodge Charger. PLENTY of room up front for a huge radiator and an intercooler.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Remote rad option and opinions street/strip car [Re: turbo toad] #2133594
08/15/16 03:50 PM
08/15/16 03:50 PM
michigan
turbo toad Offline OP
michigan
Sorry Dave if i was looking from something with more space I'd do a C body
I had a chance to get some mock up wheels on the car now that the suspension is done and get it out of the garage for the first time in a year and it looks like where the turbos are now ill beable to snake a 5"down pipe around the front tires and out the front fender behind the wheel. Also ill have enuff room to still run the radiator in the engine bay. Thanks all there was some great info had thru this thread
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Remote rad option and opinions street/strip car [Re: turbo toad] #2133710
08/15/16 06:33 PM
08/15/16 06:33 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Look up mockstang boys racing on facebook. I think they've got a YouTube video of there remote mount radiator setup on their mus tang streetcar. I plan on redoing my hotside at somepoint and going with a forward facing setup, and putting the radiator uner the trunk floor.
I've already got the dual outlet meziere water pump to do mine.
Beat me too it, Youtube: mockstang rear mount rad
Re: Remote rad option and opinions street/strip car [Re: j.mcconnell] #2133772
08/15/16 07:52 PM
08/15/16 07:52 PM
michigan
michigan
Thanks up i was having a hard tine finding it,thats a slick setup alot like what i was thinking but it filled in some blanks for me and im sure some other guys as well.
Re: Remote rad option and opinions street/strip car [Re: DusterDave] #2133781
08/15/16 08:02 PM
08/15/16 08:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the worst idea... start with a tank..
light small cars just take some work to fit
things in... in some cases .100 is a lot... I
know, I play with small cars.. at times it is
a PITA but its still light
wave
Re: Remote rad option and opinions street/strip car [Re: MR_P_BODY] #2133825
08/15/16 08:48 PM
08/15/16 08:48 PM
dogdays Offline
dogdays  Offline
Let's assume you're running 80gpm through 1 1/2" Schedule 40 pipe for 20 feet. Friction loss would be 3.5psi. Increase size to 2" and the friction loss goes to 1psi. Key is using tubing and not corrugated rubber hose. I think the airflow would be much more critical and I'd look at modern racecars to get ideas. I'm thinking like scoops in the sides of the body.
Running E85 could have a really big reduction in the heat load as well.
R.
Re: Remote rad option and opinions street/strip car [Re: dogdays] #2134028
08/16/16 12:54 AM
08/16/16 12:54 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'd guess it would take in best case a 12' run of tubing x 2 to plumb this, that's 31? lbs of water in the tubing, plus weight of the tubing, hardware, etc., You calcs for pressure drop are for straight runs, which are not likely in this type of solution?
Wait you are talking pipe, I'm thinking tubing, we are two different pages. grin
