Re: Do I need new head gaskets?
[Re: fastmark]
#2132077
08/13/16 05:05 PM
08/13/16 05:05 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yes you can but check to make sure all the teflon blue is still attached and in good shape. Nice and flat good to go. I always clean my block surface and head surface with laquire thinner right before installation.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: dvw]
#2132096
08/13/16 05:38 PM
08/13/16 05:38 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've reused them in 13-1 motors after a seasons use, never had an issue. Doug I've often wondered about reusing them on a fired up engine but was always afraid to try it. I built a very nice 360 last year and against the recommendations from Jim Dowel (Racer Brown) reused a cam that I ran for 5 years in my 408. Even with new lifters, inners removed, breaking lube, Lucus break-in oil, and immediate start-up it wiped the cam. Anyway it lasted one race and I still chicken out and didn't reuse the 1008 Felpro gaskets. I wouldn't think twice if the engine was never fired up but in my case since the engine was fired for two hours didn't want to risk the extra work and chance of screwing up another race weekend.
