Re: Wheel bearing grease...
[Re: rarefish]
#2131350
08/12/16 07:11 PM
08/12/16 07:11 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use the blonde colored wheel bearing grease made by Quaker State or Castrol. It works very well on wheel bearings.
[Re: rarefish]
#2131357
08/12/16 07:17 PM
08/12/16 07:17 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Years ago I had some of the really old stringy wheel bearing grease.. It was about the consistency of Crisco...
My mechanic friend, who I have a lot of respect for, was just crackin up when he saw I was going to use it to pack some wheel bearings.. Told me it was really old school and the more modern greases were much better....
[Re: Chris2581]
#2131449
08/12/16 08:56 PM
08/12/16 08:56 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I use the blonde colored wheel bearing grease made by Quaker State or Castrol. It works very well on wheel bearings. same here
[Re: Big_E]
#2131487
08/12/16 09:36 PM
08/12/16 09:36 PM
RapidRobert
I saw where Eberg of Mopar Action recommended Mopar Grease 4318064. I've never tried it. I think that is the green grease. I got a tube just from his recommendation. way back there was something about "long fiber' grease is what you want. I never did grasp what that was about
[Re: RapidRobert]
#2131595
08/12/16 11:11 PM
08/12/16 11:11 PM
mikemee1331
bethlehem pa
way back there was something about "long fiber' grease is what you want. I never did grasp what that was about Minivan mentioned it up above. my grandfather had that stuff back in the day.
[Re: mikemee1331]
#2131611
08/12/16 11:29 PM
08/12/16 11:29 PM
Posts: 22,721 Bitopia
jcc
Bitopia
In my 4th current Tacoma PU I have owned since new, this one with 378K miles, I decided today to change out the original front discs. That meant removing the hubs/bearings, which have never been serviced. The yellow OEM grease, still looked pretty good, and I figured if the bearings were of good enough quality to show zero signs of wear after all these miles, I couldn't figure out why to replace them with today's new junk. Bottom line, that grease must be pretty decent, whatever it is.
[Re: Big_E]
#2131728
08/13/16 02:04 AM
08/13/16 02:04 AM
RapidRobert
I'd have to check but I think the middle tube with the blue lettering is the green grease I got & the dealer sold me (1) tube (he might had ten in stock at one time)
[Re: Neil]
#2131748
08/13/16 02:45 AM
08/13/16 02:45 AM
RapidRobert
. Now if you ask for that they'll sell you 05083150AA instead. The long fiber multi-mileage lube is for suspension, steering, and u-joints. Neil just to confirm, all (3) of the tubes pictured are the long fiber good stuff?
[Re: Neil]
#2132234
08/13/16 09:22 PM
08/13/16 09:22 PM
RapidRobert
thank you Neil, I have the middle tube & just wanted to confirm it is the good stuff. I'm almost positive it was green grease & was the part # Eberg said to get
[Re: rarefish]
#2133486
08/15/16 01:21 PM
08/15/16 01:21 PM
Posts: 114 Oregon
Wagonman1967
When I apprenticed for an old Italian guy in 72 he called it horse grease. Said it was made from horses IDK. We had a 20 gallon bucket full and used it on everything,that was some sticky stinky stringy stuff. Made by Gulf IIRC.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
