Re: big block van
[Re: Rick Ray]
#2129684
08/10/16 06:23 PM
08/10/16 06:23 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
have access to a 1978 dodge van with a 440 complete. hasn't ran in 10-20 years.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: big block van
[Re: Rick Ray]
#2132355
08/14/16 12:09 AM
08/14/16 12:09 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I've got a 77 B-200 with a 318. I had a 74 Motor home with a 360 in it. That motor home had a bigger dog house than the 318 77 did. I don't have the floor from it, but I still have the dog house. Not sure what that means, except there are a few choices when looking at the dog house. you might want to check on the; http://moparbvans.proboards.com/web site as well. Lots of good info there for vanners.
I have mechanical Aptitude. I can screw up anything.
Re: big block van
[Re: Rick Ray]
#2133965
08/15/16 11:44 PM
08/15/16 11:44 PM
Posts: 10,638 Freeport IL USA
poorboy
Freeport IL USA
Like most things Mopar, between the late 60s models and about the restyle season of around 71-73, everything got bigger. That included the vans. A 72 B van is a lot bigger, and a lot more heavy then the old 60s vans were. 76-78 was the Van hay day, big motors, custom paint, custom interior, conversion vans, 4x4 versions, they were the first "adult toys". You had to install a 340 the 70s vans, they came with either a 318, or a 360, or you got a 383 (later a 400) or a 440. The big blocks hauled them around pretty good. Gene
Re: big block van
[Re: poorboy]
#2134412
08/16/16 03:32 PM
08/16/16 03:32 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
You had to install a 340 the 70s vans, they came with either a 318, or a 360, or you got a 383 (later a 400) or a 440. The big blocks hauled them around pretty good. Gene There was never a 383 van from the factory. The 360 replaced the 383 and came out in 1971. 1971 trucks still used the 383 but vans didn't. The older A vans never had a big block.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: big block van
[Re: poorboy]
#2137946
08/21/16 03:29 PM
08/21/16 03:29 PM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
Yep, gotta be big block van stuff, and its a tight fit even then. Hard to beat the results though, I got better power, and better mpg with the 400 then I ever got out of a small block van. Gene I whole heartily agree with this
Re: big block van
[Re: momopar]
#2852915
11/29/20 01:38 PM
11/29/20 01:38 PM
Posts: 3 Nooksack, washington,U.S.A.
Caseywheels
Whether it was factory or not?
Back in me youth (mid '70s) a fella a few years older than us had a late '60s Dodge window van with a 340 3 on the tree.
It was a pretty quick and quite scary ride! . If it was in Washington and Blue with a white roof.... I'd say "That was my Dad " ... 👍
Made in the back seat(almost born there too)of dad's 69 Roadrunner..I've got my own fleet now...68 Powerwagon,68 Winnebago,27 Dodge brothers hotrod,74 B350,
Re: big block van
[Re: Caseywheels]
#2854601
12/02/20 10:59 PM
12/02/20 10:59 PM
Posts: 1,771 Rustylvania
Mr_fixit
Rustylvania
2wd VAN mounts, Van exhaust manifolds, truck or van oil pick up & oil pan, van dip stick tube & stick, probably a radiator, maybe wiring, or make your own. There's probably a bunch in the junkyard, if you find one with 70's stuff. I've accumulated a couple for projects that didn't get started yet. Motor homes share a couple of the parts you need. 76 to 78 bb van would have everything you would need.
Re: big block van
[Re: Rick Ray]
#2855756
12/05/20 04:15 PM
12/05/20 04:15 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Big block van had a unique 727 case and torque converter with timing marks.
Leave the gun.......take the Cannoli's....Mike
