big block van #2129071
08/09/16 11:21 PM
08/09/16 11:21 PM
New Hampshire
Rick Ray Offline OP
Rick Ray  Offline OP
New Hampshire
Thinking about putting a 400-727 in my van.The 318 is getting tired.I have 3 400s to pick from.The van is a 1986 shorty any one here ever done this? I would think i need the truck mounts and pan.
Re: big block van [Re: Rick Ray] #2129086
08/09/16 11:43 PM
08/09/16 11:43 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Keep us updated.
Sounds like a cool build.
I would agree on the mounts and pan but do not assume,research.
Check on older models(70s).
Re: big block van [Re: Rick Ray] #2129239
08/10/16 03:33 AM
08/10/16 03:33 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I had a big block van it looked like the engine cover was wider as was the hole cut into the floor for it something you might want to check .
Re: big block van [Re: Rick Ray] #2129537
08/10/16 03:11 PM
08/10/16 03:11 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
When the big block was offered in the vans they used different mounts than the trucks.
Re: big block van [Re: Rick Ray] #2129684
08/10/16 06:23 PM
08/10/16 06:23 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
have access to a 1978 dodge van with a 440 complete. hasn't ran in 10-20 years.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: big block van [Re: hulmule] #2129851
08/10/16 10:08 PM
08/10/16 10:08 PM
New Hampshire
Rick Ray Offline OP
Rick Ray  Offline OP
New Hampshire
Where in Ohio are you? I went to Diesel school out there back in 87-88 or as my kids say the dark ages.That 78 van for sale or parts for sale?
Re: big block van [Re: Rick Ray] #2130756
08/11/16 11:54 PM
08/11/16 11:54 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Yep, gotta be big block van stuff, and its a tight fit even then. Hard to beat the results though, I got better power, and better mpg with the 400 then I ever got out of a small block van. Gene
Re: big block van [Re: poorboy] #2130892
08/12/16 07:40 AM
08/12/16 07:40 AM
New Hampshire
Rick Ray Offline OP
Rick Ray  Offline OP
New Hampshire
That's what i was thinking i had a 74-Newport years ago with a 400 and was getting 19 to 21 mpg stock.I will keep an eye out for b-block van parts.
Re: big block van [Re: Rick Ray] #2130954
08/12/16 11:19 AM
08/12/16 11:19 AM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
There were many differences between a small block and a big block van. I saw a list once on another website. The hole in the floor for the engine is to small. The engine cover is to small. It seems like some parts on the engine were also different. (Front cover perhaps and ????) I can't recall all the details, but it was a LONG list!
It would be easier to install a 360 based stroker engine. If you went this route, magnum heads and a 518 overdrive transmission should make a nice combination.
Re: big block van [Re: QuickDodge] #2132267
08/13/16 10:14 PM
08/13/16 10:14 PM
New Hampshire
Rick Ray Offline OP
Rick Ray  Offline OP
New Hampshire
I have a 5.2 in a 1994-van and 5.9 out of a 93 truck.Just think a 400 would get better mpg.There was one 1987 van running around years ago with a 383 in it may be able to track down the guy that put it in.I don't remember them having a problem with the stock dog house but i may be wrong that was years ago.
Re: big block van [Re: Rick Ray] #2132355
08/14/16 12:09 AM
08/14/16 12:09 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I've got a 77 B-200 with a 318.
I had a 74 Motor home with a 360 in it.
That motor home had a bigger dog house than the 318 77 did. I don't have the floor from it, but I still have the dog house.
Not sure what that means,
except there are a few choices when looking at the dog house.
you might want to check on the;
http://moparbvans.proboards.com/
web site as well.
Lots of good info there for vanners.
I have mechanical Aptitude.
I can screw up anything.
Re: big block van [Re: bboogieart] #2132510
08/14/16 06:57 AM
08/14/16 06:57 AM
New Hampshire
Rick Ray Offline OP
Rick Ray  Offline OP
New Hampshire
Thanks i will check it out.I have a 76 camper with a 360 also
Re: big block van [Re: Rick Ray] #2132564
08/14/16 11:43 AM
08/14/16 11:43 AM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
Whether it was factory or not?
Back in me youth (mid '70s) a fella a few years older than us had a late '60s Dodge window van with a 340 3 on the tree.
It was a pretty quick and quite scary ride!
Re: big block van [Re: Rick Ray] #2133965
08/15/16 11:44 PM
08/15/16 11:44 PM
Freeport IL USA
Freeport IL USA
Like most things Mopar, between the late 60s models and about the restyle season of around 71-73, everything got bigger. That included the vans. A 72 B van is a lot bigger, and a lot more heavy then the old 60s vans were. 76-78 was the Van hay day, big motors, custom paint, custom interior, conversion vans, 4x4 versions, they were the first "adult toys". You had to install a 340 the 70s vans, they came with either a 318, or a 360, or you got a 383 (later a 400) or a 440. The big blocks hauled them around pretty good. Gene
Re: big block van [Re: poorboy] #2134412
08/16/16 03:32 PM
08/16/16 03:32 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
There was never a 383 van from the factory. The 360 replaced the 383 and came out in 1971. 1971 trucks still used the 383 but vans didn't. The older A vans never had a big block.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: big block van [Re: poorboy] #2137946
08/21/16 03:29 PM
08/21/16 03:29 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I whole heartily agree with this
Re: big block van [Re: Rick Ray] #2137950
08/21/16 03:37 PM
08/21/16 03:37 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I had a 1975 American Clipper with a 440. The worst thing about them was the stock exhaust manifolds. I swapped them out with headers, THE best change I made on that thing! Not only did the stock manifolds crack but they got the floor and dog house super hot. All that changed with headers. It did seem like the dog house hole size was bigger on my motor home than it was in the old work van I used to have, but not positive it was.
Re: big block van [Re: momopar] #2852915
11/29/20 01:38 PM
11/29/20 01:38 PM
Nooksack, washington,U.S.A.
Caseywheels Offline
Caseywheels  Offline
. If it was in Washington and Blue with a white roof....
I'd say "That was my Dad " ... 👍
Made in the back seat(almost born there too)of dad's 69 Roadrunner..I've got my own fleet now...68 Powerwagon,68 Winnebago,27 Dodge brothers hotrod,74 B350,
Re: big block van [Re: Caseywheels] #2854601
12/02/20 10:59 PM
12/02/20 10:59 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
2wd VAN mounts, Van exhaust manifolds, truck or van oil pick up & oil pan, van dip stick tube & stick, probably a radiator, maybe wiring, or make your own. There's probably a bunch in the junkyard, if you find one with 70's stuff. I've accumulated a couple for projects that didn't get started yet. Motor homes share a couple of the parts you need. 76 to 78 bb van would have everything you would need.
Re: big block van [Re: Rick Ray] #2855756
12/05/20 04:15 PM
12/05/20 04:15 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Big block van had a unique 727 case and torque converter with timing marks.
Leave the gun.......take the Cannoli's....Mike
