Re: Diaelectric grease on new rotor and cap contacts??
[Re: mikemee1331]
#2129969
08/10/16 11:53 PM
08/10/16 11:53 PM
RapidRobert
Yea, on the rotor center blade that contacts the cap center button. it can help minimize radio/stereo static. not a dealbreaker but it can help by minimizing the minute make/break of continuity there as those 2 dissimilar surfaces contact each other in motion
[Re: MidPenMopar]
#2129985
08/11/16 12:04 AM
08/11/16 12:04 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
Never That would make a heck of a dust and debris collector inside the distributor cap, huh
[Re: MidPenMopar]
#2130351
08/11/16 03:23 PM
08/11/16 03:23 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I use Castle dielectric on the ends for plugs.That wahy the boots dont stick.Use it on wire connections especially where they are in the elements.Used it since the 80s at work and at home.never any problems.Dont use it on the cap/rotor.Rocky
Chrysler Firepower
[Re: Challenger 1]
#2130539
08/11/16 07:31 PM
08/11/16 07:31 PM
RapidRobert
Yea, on the rotor center blade that contacts the cap center button. it can help minimize radio/stereo static. not a dealbreaker but it can help by minimizing the minute make/break of continuity there as those 2 dissimilar surfaces contact each other in motion too technical? (my apologies!)
[Re: mikemee1331]
#2131783
08/13/16 07:29 AM
08/13/16 07:29 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The modification most often done to improve high rpm distributor cap and rotor performance is to vent away with airflow the ions created by internal sparking. I guess here the question is whether and how to filter this ventilation of the cap's insides. Yes, but i believe you need a tricorder in order to encapsulate said ions...... sorry, i've been on a Star Trek, Next Generation binge...... No, no, no.... You put on a helmet, lower the blast shield to block your vision, Then slowly develop and enhance Your feeling for The Force. Helps to have Obi Wan Kenobi Beside you as a tutor.
