Help w/ cam and head swap on #2129743
08/10/16 07:46 PM
08/10/16 07:46 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
I have a stock 1972 Plymouth Duster 340. I am replacing my heads for some re-manufactured cylinder heads from Aerohead Racing w/ stainless 2.02's for the valves. The heads Aerohead racing ARO-CY-SB340. The springs are single w/ a damper spring inside of that. Seat pressure is 125 lbs. I want to use the XE274H cam. What do I need to make this work? A buddy tells me these springs will wipe the cam as it is too harsh. Help!
Thanks,
Reno340
I Am The Big Dog
View My Photos
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Help w/ cam and head swap on [Re: reno340] #2129906
08/10/16 10:58 PM
08/10/16 10:58 PM
actually 125 seems OK even light but I would call the cam company (comp cams?). I would also measure your open (compressed) height dimention since you have access to a scale. I would in addition check coil bind/VP clearance/wipe pattern/pushrod angle/rocker to retainer clearances/retainer to seal, all the std stuff
Re: Help w/ cam and head swap on [Re: reno340] #2129920
08/10/16 11:09 PM
08/10/16 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume this is a hyd cam.. 125 does seem
light... call the cam company and see what
they say
wave
Re: Help w/ cam and head swap on [Re: reno340] #2130038
08/11/16 12:39 AM
08/11/16 12:39 AM
Seat pressure doesn't wear out the cam, coil bind and to much opened pressure will work shruggy I've used 140 to 175 lbs on the seats on many flat tappet motors with both hydraulic and solid lifters in them, BB, Hemi and LA SB up On your deal it pays to make sure, the learning experiences are worth your time thumbs Call Comp in the morning and see what the minumums and maximums spring pressure are on what they recommend for both closed and open scope
Please let us know what you find out work
