SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY #2129247
08/10/16 03:13 AM
08/10/16 03:13 AM
Sweden
71redcuda Offline OP
Sweden
I need to see some pictures of original shaker cable mounting hardware (on the base plate)
I have only found 1 pics shown here..
Nicklas
Re: SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY [Re: 71redcuda] #2129252
08/10/16 04:33 AM
08/10/16 04:33 AM
WA
tman Offline
tman  Offline
WA
Re: SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY [Re: 71redcuda] #2129852
08/10/16 09:09 PM
08/10/16 09:09 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The old shaker reference threads are getting tough to pull up with the search engine so I'll post this pic from an old thread..This one is courtesy of member Mccanix showing the original hardware used on the bellcrank...
Re: SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY [Re: 71redcuda] #2130093
08/11/16 03:24 AM
08/11/16 03:24 AM
Sweden
Sweden
Thank You so much!
Really appreciate The picture.
Nicklas
Re: SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY [Re: 71redcuda] #2130134
08/11/16 08:34 AM
08/11/16 08:34 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
13,000 mile Hemicuda with push on clips
68 Charger
70 Cuda
Re: SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY [Re: 71redcuda] #2130280
08/11/16 12:20 PM
08/11/16 12:20 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
9000 mile 383 Cuda yard wrecked, with the other correct clips.
Both styles were used.
I've seen them both ways....time frames for each not known.
One Chrysler print exists showing the 'C' clips.
This Fram print shows the bellcrank before assembly with
Fram 'pin' ( clip ) their number 234218, shown on the above bellcrank.
Bottom cable is a repro I put on for picture as original one was broken.
Re: SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY [Re: 71redcuda] #2130737
08/11/16 10:38 PM
08/11/16 10:38 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Hemicuda above 5/25 SPD if that helps for time reference.
Tom
68 Charger
70 Cuda
Re: SHAKER CABLES MOUNTING HARDWARE ON BASE PLATE..E-BODY [Re: 71redcuda] #2130803
08/11/16 11:44 PM
08/11/16 11:44 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I assume that would be 5/25 on a 70 Hemicuda Tom.
It was obviously assembly line installed items, so hard to figure a time reference.
I would bet plenty left the line with neither style.
Here's a picture from a 71 340 3/21...a lot more miles, but was from what I know, an undisturbed shaker car
