Pro ratchet Foward Shift electric shifnoid #2129191
08/10/16 01:33 AM
08/10/16 01:33 AM
ky, usa
littlejohn44 Offline OP
ky, usa
Has anyone rigged up a electric noid on a forward pattern Pro ratchet? looks to me a custom flipped bracket and the noid for the reverse mounted foward. Does anyone have any ideas or pictures of their set up?
Re: Pro ratchet Foward Shift electric shifnoid [Re: littlejohn44] #2130025
08/11/16 12:31 AM
08/11/16 12:31 AM
ky, usa
ky, usa
Does anyone even use a foward pattern Ratchet?
Re: Pro ratchet Foward Shift electric shifnoid [Re: littlejohn44] #2130863
08/12/16 02:28 AM
08/12/16 02:28 AM
ky, usa
ky, usa
Wow still no suggestions
Re: Pro ratchet Foward Shift electric shifnoid [Re: littlejohn44] #2130953
08/12/16 11:18 AM
08/12/16 11:18 AM
Mi USA
Dyno Donnie Offline
Dyno Donnie  Offline
Mi USA
Switched from 727 3-sp to glide. Had to purchase the other
pro rachet for a glide (torque flt pro rachet shifter will not work with 2 sp . then just hour after hour of labor fabricating
mounting bracket and new threaded bolts to front of shifter on
trans tunnel. rpm activated shifter switch was a god sent for
trial after trial. Sorry no pictures.
Re: Pro ratchet Foward Shift electric shifnoid [Re: littlejohn44] #2130969
08/12/16 11:50 AM
08/12/16 11:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think a reversed bracket would work
fine... I use a reverse manual Pro Ratchet and
had the shiftnoid on it
wave
Re: Pro ratchet Foward Shift electric shifnoid [Re: littlejohn44] #2131164
08/12/16 03:07 PM
08/12/16 03:07 PM
ky, usa
ky, usa
I have a reverse manual pro with the shifnoad and i got to run it for the first time last night and I love it. I switched from the hurst. I am trying to help a buddy out. He is the one with the foward pattern and its in a 442 so i told him i would ask since we have the most knowledgeable and friendly people hands down. I was starting to think I was gonna eat crow with nobody posting.
