last yr. for the 413 #212827
02/03/09 10:48 AM
02/03/09 10:48 AM
pacific northwest
W
wings471 Offline OP
wings471  Offline OP
W
pacific northwest
When was the last year the 413 was manufactured?
Re: last yr. for the 413 [Re: wings471] #212828
02/03/09 10:54 AM
02/03/09 10:54 AM
OMAHA
poly Offline
poly  Offline
OMAHA
perty sure that the last year it was used in cars was 65, however I beleive that it was still used in trucks and campers after that
Re: last yr. for the 413 [Re: poly] #212829
02/03/09 11:00 AM
02/03/09 11:00 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, it was made up into the 70's typically for motor homes. Why they didn't just go to 440's I have no idea, maybe to aid in cyl wall thickness in an attempt to keep them running cooler in HD applications?
Re: last yr. for the 413 [Re: ScottSmith_Harms] #212830
02/03/09 11:08 AM
02/03/09 11:08 AM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
1973 to be exact.
And the reason for the 413 ...was that it was a better motor(for the application) .. than the 440 was.
Re: last yr. for the 413 [Re: IcorkSOAK] #212831
02/03/09 11:11 AM
02/03/09 11:11 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
better in what way doc? Unless the casting was heavier/thicker what advantage would it have over a 440? Milage?
Re: last yr. for the 413 [Re: ScottSmith_Harms] #212832
02/03/09 11:17 AM
02/03/09 11:17 AM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
SSH .. The block was heftier, the heads were THE BEST for an RV or truck(although junk for HP), cooling system was overkill ....and I have been told that ALL the cranks were flame-hardened.
And how about that COOLANT-heated intake manifold ?
Re: last yr. for the 413 [Re: IcorkSOAK] #212833
02/03/09 11:21 AM
02/03/09 11:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm aware of all that, my question is: "Why not incorporate all of that into a 440"?
Re: last yr. for the 413 [Re: ScottSmith_Harms] #212834
02/03/09 11:25 AM
02/03/09 11:25 AM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
I don't know .... but they dropped the 413 becuase it was costing something like 200$ more each to produce.
Have you ever really looked at those heads ...and water pump assembly ?
Re: last yr. for the 413 [Re: IcorkSOAK] #212835
02/03/09 12:19 PM
02/03/09 12:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, I own a set, pretty much over engineered as you said
Re: last yr. for the 413 [Re: ScottSmith_Harms] #212836
02/03/09 02:23 PM
02/03/09 02:23 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
What are you going to do with the heads you have ? ..... I am going to have a set flowed and have them modified to a "swirl-port" design for my two different motorhomes.
Re: last yr. for the 413 [Re: IcorkSOAK] #212837
02/03/09 02:36 PM
02/03/09 02:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I should have worded that diferently. They aren't actually owned by me, they are a customers, I have the entire engine stored in my barn. If you are interested in it I'll find out if he'd sell it and put you guys in touch directly.
Re: last yr. for the 413 [Re: IcorkSOAK] #212838
02/03/09 05:39 PM
02/03/09 05:39 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Are all 413 blocks thicker or just the mtr home blocks? Reason I ask is I have 63 and a 65 413 block. How much can you bore a 413?
Re: last yr. for the 413 [Re: pushbutton] #212839
02/04/09 10:43 AM
02/04/09 10:43 AM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Some have said .. that the MH 413 block is a thick-wall 440 ... that is only bored to 4.1875.
How far can you go ? .. I plan on doing some sonic-checking myself to get first-hand specifics .. but I have been told that some dead-stock blocks have cyl walls as thick as .250.
The early 413's ? ... are not near as fortunate as that.
Re: last yr. for the 413 [Re: IcorkSOAK] #212840
02/05/09 12:41 AM
02/05/09 12:41 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I have a 62 413 block that we are using to build a motor for the wife's 64 fury. It came out of a 62 Imperial. I don't recall the actual thickness, but the cylinder walls sonic checked very thick.
We bored it .060 over to 426 size, but could've gone to 440 size without a problem.
Re: last yr. for the 413 [Re: G_bob] #212841
02/05/09 01:18 AM
02/05/09 01:18 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
I've got a fresh rebuilt 413 MH engine sitting here in the corner. the guy had it rebuilt for his grain truck, and then passed away. not a mile on it. anybody interested? I got ahold of a 426 street wedge from another member here, and have moved on past the 413 "idea".
