Re: Opinions on Tach and Racing Seat Belts for the Dart
[Re: MuuMuu101]
#2128206
08/08/16 09:49 PM
08/08/16 09:49 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Go with red belts for sure, you have enough black already. I would put the tach where that crank in the middle of the dash is as long as it's not one of those huge ones. I have mounted a tach on the pillar above the VIN number, there is a screw about 6 inch up that you can use to mount it, that would be the most visible location.
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#2128252
08/08/16 10:41 PM
08/08/16 10:41 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
When I switched over to running hill climb I used a shift light. Same came in handy when running a road course.
Abe Lincoln
[Re: MuuMuu101]
#2128787
08/09/16 04:35 PM
08/09/16 04:35 PM
dart4forte
Mesa, Arizona
I think I'm liking the tachometer on the A-pillar. Do you guys have a specific tachometer or brand you recommend? I like my eyes on the track. A tach there is distracting
Abe Lincoln
[Re: MuuMuu101]
#2128791
08/09/16 04:43 PM
08/09/16 04:43 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
5 inch monster tach in my 65.On the dash with shift light.I had it under the pad till the pad got crappy looking.As for belts Id say red against the black.We run RJS 5 point belts with the round release.As goos as Simpsons IMO but less $$$$.Rocky
Chrysler Firepower
[Re: 383man]
#2129227
08/10/16 02:46 AM
08/10/16 02:46 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
This is where my son mounted his tach in his 72 Dart. He can still see all his stock gauges ok. Myself I would go with black seatbelts in your car. Ron Looking at the pictures of my dash, there might be some room for a very tiny one on the right side of the column, right next to what I believe is the wiper knob. Thinking about it again, above the dash would probably be a little distracting in an autocross or road race condition. I guess if I get a small tachometer and play around with the position I can see which I like best. My rev limiter will probably be set to about 6500 or so. Maybe a shift light on the dash or the steering column ( https://www.summitracing.com/parts/sum-g2945/overview/) and a small gauge in that small area ( https://www.summitracing.com/parts/atm-2698/overview/ or https://www.summitracing.com/parts/atm-2892/overview/)?
[Re: MuuMuu101]
#2131010
08/12/16 12:27 PM
08/12/16 12:27 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Yep, watching a tach is distracting. Use a good shift light mounted close to your line of sight to shift. A tach is for setting idle speed and checking the shift light. Mount it out of the way.
[Re: MuuMuu101]
#2131129
08/12/16 02:40 PM
08/12/16 02:40 PM
therocks
Niles , Ohio
The shift light on my tach is so bright even in the day with the cover on I can see it.At night you never have to even look close to it.It lights up the inside.Its an Autometer 5 inch with light.Rocky
Chrysler Firepower
