Re: my 69 rr black, pewter int and pewter painted roof
[Re: Black 69 Beeper]
#2126397
08/06/16 10:32 AM
08/06/16 10:32 AM
Posts: 937 new jersey
Black 69 Beeper
new jersey
I used 3M-8329 controlled flow 2 part seam sealer for the drip rails. The stuff is really nice. I first cleaned the drip rails, then epoxy sealed the with PPG DP90LF. The roof, rear deck panel, edges of the trunk jam and the rockers have 3 coats of PPG K36 urethane high build primer on them and they have been guide coated. They will be block sanded by hand with 320 and possibly re-coated if need be.
#2131023
08/12/16 12:36 PM
08/12/16 12:36 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I still look at every update on this thread...very nice job you're doing! Why no subframe connectors if you plan on racing it some? Or is this a numbers matching drivetrain car still?
[Re: RJS]
#2242568
01/28/17 12:21 AM
01/28/17 12:21 AM
Black 69 Beeper
new jersey
rr
