Getting ready to change fuel pump #2127662
08/08/16 05:39 AM
08/08/16 05:39 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I've removed the alternator and getting ready to change the fuel pump and fuel filter. I was going to follow the "fuel pump replacement " part of this guide:
http://www.aa1car.com/library/fuel_pump_mechanical.htm
What's the best way to deal with the pushrod when I take off the pump, will it fall out? I have bought some grease that I'm hoping will keep the rod in place while installing the pump.
Attached is a pic of the pump.
https://drive.google.com/file/d/0B8IgeG75F_MIMTRyTFF5TWUyRDg/view?usp=drivesdk
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Getting ready to change fuel pump [Re: xyxxjx] #2127678
08/08/16 08:35 AM
08/08/16 08:35 AM
md
mopars4ever Offline
mopars4ever  Offline
md
The rod won`t fall out. It can drop down and get in the way when reinstalling the pump. That`s why people put grease on it to get it to stay up while putting the pump back on.
Re: Getting ready to change fuel pump [Re: xyxxjx] #2127714
08/08/16 10:40 AM
08/08/16 10:40 AM
WI
E
eric383 Offline
eric383  Offline
E
WI
While you have access to the push rod do yourself a favor and measure it to make sure it isn't worn. It should be 3.22" and reinstall the push rod in the same way it came out. The end that rides against the cam should go against the cam upon installation.
Re: Getting ready to change fuel pump [Re: mopars4ever] #2128049
08/08/16 06:13 PM
08/08/16 06:13 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Thanks, I can picture it now.
Re: Getting ready to change fuel pump [Re: eric383] #2128050
08/08/16 06:14 PM
08/08/16 06:14 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Thanks, will keep that in mind.
Re: Getting ready to change fuel pump [Re: xyxxjx] #2128051
08/08/16 06:21 PM
08/08/16 06:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
If you want to pull the rod out to measure you will need to remove the plug in the block for it to slide out. It can be a pain to get that plug out at times as they can be really tight.
Re: Getting ready to change fuel pump [Re: mopars4ever] #2128058
08/08/16 06:34 PM
08/08/16 06:34 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
The car only have 50k miles on it, I'll take the chance and leave it in there.
