Leaf spring replacement #2127532
08/07/16 11:42 PM
08/07/16 11:42 PM
Illinois
Tinman761 Offline OP
Illinois
Hello everyone, I'm looking to replace the leaf springs in my 67 coronet 383 4bbl, because it's starting to sag and the bushings are worn out. What would be a good source. Thanks again
Re: Leaf spring replacement [Re: Tinman761] #2127598
08/08/16 12:29 AM
08/08/16 12:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If yours are still unbroken and un damaged see if they can be rearched.Better than almost any aftermarket ones.had my kids done for 125 for the pair and an extra leaf and 1 inch extra arch.They can replace the bushings also at a good spring shop.Other than that for stock bushing they usually come in new springs.Mancin ,Springs and things etc should have them.Rocky
Chrysler Firepower
Re: Leaf spring replacement [Re: therocks] #2127649
08/08/16 03:24 AM
08/08/16 03:24 AM
I would remove the springs & clamp the spring aways back from the center bolt with (2) C clamps on each side then split the nut with a nut cracker then undo em & seperate the leafs & have a spring shop rearch the main leaf & replace the front bushing as needed then bring em home & reassemble. they will ask you how much lift you want & I would measure the height now & jack it up till it is where you want it/looks right then note that dimention difference to give to the shop or purchase a tailor made spring set, ESPO has a good record & 1" over stock is recommended
Re: Leaf spring replacement [Re: Tinman761] #2127906
08/08/16 02:45 PM
08/08/16 02:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Call laura at ESPO / springs and things.
http://www.springsnthings.com/ up beer
Re: Leaf spring replacement [Re: Tinman761] #2128016
08/08/16 05:35 PM
08/08/16 05:35 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
While Im not against adding a leaf, be aware that this significantly raises your spring rate.
Rearching the entire assembly is my favourite method of changing ride height.
Re: Leaf spring replacement [Re: Tinman761] #2128025
08/08/16 05:47 PM
08/08/16 05:47 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Every '60s Mopar could use some extra spring rate, front and back, to get a more positive handling car.
Adding a leaf is not real difficult.
I would only consider replacing the leafspring pack if the leafs are S-shaped or are arching the opposite way.
If you want butter soft suspension you should've bought a Cadillac... wink
Re: Leaf spring replacement [Re: TJP] #2128043
08/08/16 06:07 PM
08/08/16 06:07 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I double that !! boogie beer
Re: Leaf spring replacement [Re: TOMRR] #2128072
08/08/16 06:52 PM
08/08/16 06:52 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
How bad is it sagging??
I took mine apart, wire wheeled them, painted, new zinc and plastic ends, and reinstalled with new bushings...
I wanted my car to sit a "touch" low so I thought reusing my rebuilt springs would be what I wanted.. My car did have the Hemi leaf pattern....
Re: Leaf spring replacement [Re: Tinman761] #2128302
08/08/16 11:33 PM
08/08/16 11:33 PM
Illinois
Illinois
Thanks everyone for the advice. Can't decide whether to have them rearched or buy a new set.
Re: Leaf spring replacement [Re: TJP] #2128343
08/09/16 12:05 AM
08/09/16 12:05 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
X3, she's great!
Admiration For Multiple Carburetor Vehicles...
Re: Leaf spring replacement [Re: Tinman761] #2128586
08/09/16 12:04 PM
08/09/16 12:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Unless they are real bad or local shop is crazy on rearching they will, be better than any new ones.We had the 62s done at least 15 years ago and they were still like new when he sold the car.That was after at least 25K highway miles and lots of 1/4 mile runs.Rocky
Chrysler Firepower
Re: Leaf spring replacement [Re: Tinman761] #2128800
08/09/16 05:13 PM
08/09/16 05:13 PM
Salinas, CA USA
70swinger340 Offline
Salinas, CA USA
Have you considered the MOpar Perf XHD replacement springs? I've used them and super stock springs and have liked them both. The SS springs are just a little rigid for everyday driving
Re: Leaf spring replacement [Re: 70swinger340] #2129216
08/10/16 02:08 AM
08/10/16 02:08 AM
I had a 65 dart SB with 003/003 MP springs (came that way as a roller) & it rode high and tight (it was great). I'd go that route again in a heartbeat.
