Most powerful alternator on stock wiring #2126960
08/07/16 05:31 AM
08/07/16 05:31 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I'm in the process of changing the fuel pump . I'm thinking about changing the alternator too since i have to take it off to get to the fuel pump. What's the most powerful alternator I can run on the stock wire gauges? I'm looking for b4b (bang for the buck) solution.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127053
08/07/16 12:01 PM
08/07/16 12:01 PM
Andrewh Offline
Andrewh  Offline
The common misconception is that the alt drives an amount of current. That is not true.
you can put a 2000 amp alt on any car and the car will not burn up.
it is based on the draw the car needs.
As for bang for your buck, the 2 field 89 new yorker is a 74 or 78 amp alt you can pick up at any parts store for 50 bucks.
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127071
08/07/16 12:30 PM
08/07/16 12:30 PM
South Carolina
carhunter Offline
carhunter  Offline
South Carolina
iagree
There was an article about this not that long ago,look in the search for it. Will it fry my wiring/gauges/etc.on 7-21-16
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127080
08/07/16 12:46 PM
08/07/16 12:46 PM
If things are OK now I would suggest leaving it as is & concentrate on the issues that need to be dealt with. If you pull/clean the bulkhead it will take care of most any potential electrical issues & never use the alt to charge a depleted battery (use a regular battery charger). Otherwise as said the 78 amper is the most powerful stock one except for the big 100 amp beast with the fan blades behind the pulley & it has special bracketry & is heavy but is a good piece. the 78 amper has a thin stator so a slight fore/aft mounting adjustment is needed (washers/spacers)
Re: Most powerful alternator on stock wiring [Re: RapidRobert] #2127121
08/07/16 01:53 PM
08/07/16 01:53 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
While I tend to agree without supporting evidence, fact is that likely 99 percent of those of us who ever had their car jump started are guilty as charged.
As noted just yesterday in a posting in response to a thread on this forum, I did exactly this. Battery on my Challenger was almost completely discharged(11.3) volts, jumped with a lithium battery pack, drove off once car was started with the amp gauge pegged for the 1st 15 miles as the gauge slowly returned to the center.
Yes admittedly this fear was at the top of my mind as I silently urged the amp gauge needle to hurry up and find its way to its natural home.
Checked battery when arriving back home, meter showed 12.9 bolts. Today I will be analyzing to find why the fairly new battery self discharged as the car set for 3 plus weeks with the only draw being the tick tick dash clock.
Re: Most powerful alternator on stock wiring [Re: Andrewh] #2127123
08/07/16 01:57 PM
08/07/16 01:57 PM
5thAve Offline
5thAve  Offline
At the same time tho the wiring is usually sized for the stock alternator. If you need a bigger alternator you're going to be pulling more current then the wiring was designed for so you should be using bigger gauge wiring to match. But if someone is just upping the size of their alternator for the hell of it then it doesn't matter.
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127128
08/07/16 02:03 PM
08/07/16 02:03 PM
BDW Online content
BDW  Online Content
If you do the amp bypass, run a large wire directly from alternator to battery relay, you won't have to worry about the stock wiring carrying the load.
Re: Most powerful alternator on stock wiring [Re: BDW] #2127142
08/07/16 02:28 PM
08/07/16 02:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Battery relay?
You realize that all electrical loads are, by design, supported by the alternator when the engine is running. All your "trick" does is feed the battery direct, everything else still pulls off the stock wiring and now you've severely increased the load on the wiring from the battery to the fuse box. Prior to your "trick" that load came from the alternator output to the fuse box. This is a poorly thought out "cure" for a problem that shouldn't exist.
Don't be the exception.
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127178
08/07/16 03:38 PM
08/07/16 03:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I got 2 cars with these alternators, one since 2005. They are stock cases nothing special on the outside and cost about 150 bucks I think? I really can't remember somewhere around there.
Is it worth it? Yea I think so because they charge better at idle.
One my cars have stock wiring and AC that is why I wanted a up graded alternator for at night during the summer with the AC running. My lites stay more steady now at idle or low speeds.
No trouble out of either alternator so far, one since 2005.
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127186
08/07/16 03:50 PM
08/07/16 03:50 PM
BDW Online content
BDW  Online Content
Good catch, it's actually the starter relay.
Nice to have someone with plenty of free time to clear up important things.
http://www.allpar.com/history/mopar/electrical.html
Stock wiring can handle the stock loads.
Any new parts, electrical fuel pumps or fans, should also be run directly off alternator through a relay.
Re: Most powerful alternator on stock wiring [Re: Challenger 1] #2127223
08/07/16 04:52 PM
08/07/16 04:52 PM
None
71rm23 Offline
71rm23  Offline
None
I have the same one, double pulley, challenger1. Just received and waiting for another part to install on my engine. Trying to get all engine stuff on my engine after paint
Re: Most powerful alternator on stock wiring [Re: 71rm23] #2127256
08/07/16 05:42 PM
08/07/16 05:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
I hope your happy with it. I think you will be. Good luck on your motor build.
My motor in 05 and it is still in the car just like this. I haven't taken anything off of it since I don't think? except I went with stock painted valve covers before it went into the car.
Some spare parts I threw together into this 318 challenger.
Donut cutter before Woodward last summer 2015.
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127572
08/08/16 12:06 AM
08/08/16 12:06 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I wasn't able to find this 78 amp alternator. Anyone have a link to one?
Re: Most powerful alternator on stock wiring [Re: RapidRobert] #2127579
08/08/16 12:13 AM
08/08/16 12:13 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
This is am excerpt from the link someone posted earlier.
"If your original alternator was 35 amps or less, we also recommend that you change the ammeter wiring to a thicker gauge. This will allow the charging system to use the extra amps more efficiently without having to worry about overheating or melting your existing ammeter wiring harness."
But you guys are saying if I put the 78 amp alt in I won't have to worry about melting wires, right?
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127595
08/08/16 12:25 AM
08/08/16 12:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run the chrome unit like Challangers.Been in th 65 since 2000.No problems ever but I dont have much draw.My kid uped the alt in the 62 300 when he had it went from 35 to 65.ran it for almost 15 years.no problems and he ran a big stereo and hi output headlight but they were halogens like in my 65.Alt wont usually creat a problem unless you have lots of after market add ons.I do bypass the amp meter as they were bad even new.A larger alt and replacing the points reg with the solid state makes idle lighting better.Rocky
Chrysler Firepower
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127613
08/08/16 01:14 AM
08/08/16 01:14 AM
correct. clean the bulkhead male/female brass terminals well especially the 2 main in/out circuits (4 brass terminals)/clean large batt cables including ground path (batt to block/block to firewall) and keep the ammeter needle close to 12 O'clock.
Re: Most powerful alternator on stock wiring [Re: RapidRobert] #2127631
08/08/16 01:58 AM
08/08/16 01:58 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Mopar electronics, what me worry?
Re: Most powerful alternator on stock wiring [Re: RapidRobert] #2127656
08/08/16 04:44 AM
08/08/16 04:44 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
BTW here's my current alternator, just want to make that it is the 35amp version. Is there a way to see that from the attached pics?
https://drive.google.com/file/d/0B8IgeG75F_MIOVhEYVBOdk1DM0U/view?usp=drivesdk
https://drive.google.com/file/d/0B8IgeG75F_MIRjFFa21aN0ZEVzA/view?usp=drivesdk
Re: Most powerful alternator on stock wiring [Re: Challenger 1] #2127663
08/08/16 05:46 AM
08/08/16 05:46 AM
None
71rm23 Offline
71rm23  Offline
None
Me too, Challenger1. I think I know where the bracketry and everything else came from on your car. It sure looks good! I have everything as you do on your car. I just have to get working on it when I get back home. Oh, the list is looong for things to do
Re: Most powerful alternator on stock wiring [Re: xyxxjx] #2127664
08/08/16 05:49 AM
08/08/16 05:49 AM
None
71rm23 Offline
71rm23  Offline
None
http://www.powermastermotorsports.com/mopar2.html smile
