A body master cylinder help wanted #2126586
08/06/16 03:57 PM
08/06/16 03:57 PM
Spencer NY
killermopar Offline OP
Spencer NY
What master cylinder for a 73 Dart with manual disk brakes? Drums on rear.
Re: A body master cylinder help wanted [Re: killermopar] #2126597
08/06/16 04:14 PM
08/06/16 04:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
?? Not sure what the question is.
Stock replacement RAYBESTOS MC36412
1 1/8" bore.
Don't be the exception.
Re: A body master cylinder help wanted [Re: killermopar] #2126606
08/06/16 04:30 PM
08/06/16 04:30 PM
Spencer NY
Spencer NY
Thank you. I had to do a conversion. Must be the car was an early one or something. Just making sure the stock type is the right deal. Again thank you
Re: A body master cylinder help wanted [Re: killermopar] #2126614
08/06/16 04:46 PM
08/06/16 04:46 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
whoa...no way to a 1 1/8 bore!!!! that's for a D150! Pedal will be as hard as a rock.
The stock is 1 1/32. I would use a 15/16 personally.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: A body master cylinder help wanted [Re: killermopar] #2126618
08/06/16 05:00 PM
08/06/16 05:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Can't add much to what goldduster318 stated.... albeit my application is race only, I prefer having a little pedal travel/feel if I need to grab brakes at the stripe. Can't remember what bore I had on the Mirada, but it was like pressing your foot against a wall....hated that. The 15/16" I have in the Duster is just right in my book.
Re: A body master cylinder help wanted [Re: killermopar] #2126622
08/06/16 05:04 PM
08/06/16 05:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Damn, brain farted it, saw 1 1/32", wrote 1 1/8".
Per FSM Manual Disc brakes, A body. M/C bore 1.032"
Re: A body master cylinder help wanted [Re: Supercuda] #2127004
08/07/16 10:50 AM
08/07/16 10:50 AM
moparx Offline
moparx  Offline
raybestos # F88787 1 1/32" bore as stated.
beer
