8 bolt flywheel? #212557
02/03/09 12:36 AM
02/03/09 12:36 AM
Alberta, Can
JUST_N_TIME Offline OP
Alberta, Can
not a stick guy.
Are 8 bolt flywheels to fit small block cranks readily available from aftermarket or? If so, from whom and est. price.
thanks
Re: 8 bolt flywheel? [Re: JUST_N_TIME] #212558
02/03/09 10:24 AM
02/03/09 10:24 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The flywheel does not care what engine it's bolted to , if it fits the crank and is the correct balnce for your engine/bellhousing combo then you are all set .
Do you need a 130 tooth or a 143 tooth ? do you want cast iron (steel?) , billet steel , or aluminum with an insert?
You can get them from all the usual suspects that sell flywheels and price will depend on what you want ...
