Conquest to victory #212510
02/02/09 10:22 PM
02/02/09 10:22 PM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
Here's the question,,,,,,I bought a 87 conquest to day with the plans of dropping a smallblock in it,,,,,,anyone out there already done this,,,,what am I going to run into while doing this
Re: Conquest to victory [Re: poly] #212511
02/02/09 11:34 PM
02/02/09 11:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Doable, but you better be crafty with the welder, nothing is a drop-in. Get ready to fab your own motor and trans mounts and convert to an aftermarket shifter. Not sure how much power the stock rear end in those things will take, but your driveshaft will need to be custom either way. Sounds like a fun project.
Re: Conquest to victory [Re: poly] #212512
02/02/09 11:42 PM
02/02/09 11:42 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I have always wanted to do a 360 swap into a Conquest. I would like to follow along with your build if you do it!
Re: Conquest to victory [Re: poly] #212513
02/03/09 08:04 AM
02/03/09 08:04 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I helped a guy (I did most of the work because I could weld while he scrounged up all the parts) get started on one. We got the oil pan worked out and had the motor in the car. Then he decided to take it to his place (apartment) so he could mess with it any time he wanted and it ended up getting towed and disappeared. I've got pictures somewhere if you're interested.
Re: Conquest to victory [Re: FuryUs] #212514
02/03/09 10:47 AM
02/03/09 10:47 AM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
Definitely interested in any pics. and would like to hear about the oil pan, as the preliminary measurements look to be a problem with the pan, overall measurements look like they will work with the engine compartment
Re: Conquest to victory [Re: poly] #212515
02/03/09 08:28 PM
02/03/09 08:28 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I can't seem to find the pics right now...
High Performance Mopar did a series on swapping a 340 into a Conquest. Their approach was to cut out the cross member and build a new one that worked around their oil pan. Then they built some funky headers to fit around it all.
We decided to rework the pan around the stock crossmember. We cut the pan and spun it around so the sump was on the opposite end. After that, the motor dropped right in between the inner fenders with the stock manifolds on. The plan was to try some truck headers from Summit that looked like they would fit but we never got that far. I also swung the alternator up and modded the brackets to work and made up some brackets to mount the stock Conquest power steering pump to the motor on the driver's side opposite the alternator. One good bash on the passenger side of the floor board and the auto tranny would have fit (I don't remember if it was a 727 or 904).
Re: Conquest to victory [Re: FuryUs] #212516
02/04/09 10:50 AM
02/04/09 10:50 AM
N.Y.
V
VZCharger Offline
VZCharger  Offline
V
N.Y.
Check out Starquestclub.com , in the engine modifications under the forums. There are lots of guys there swapping just about everything into Conquest/Starions.
I looked at it for a while as I've had a few Conquest and a spare 340 laying around, but my stock 89 just runs too well as is. Though I do have an 88 sitting here I've been using for parts
70 Charger blown injected BB
07 Charger Daytona Plum Crazy #389
69 Coronet ragtop
96 Ram "Garlits Edition"
88 Conquest TSi
Re: Conquest to victory [Re: VZCharger] #212517
02/04/09 11:00 AM
02/04/09 11:00 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I remember that HPM article... I probably have that issue somewhere. IIRC the headers were multi-piece.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Conquest to victory [Re: BBR] #212518
02/06/09 12:50 PM
02/06/09 12:50 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Found the pics! Here's the oil pan sliced, diced, spun, and tacked in place.
Re: Conquest to victory [Re: FuryUs] #212519
02/06/09 12:51 PM
02/06/09 12:51 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
And here it is sitting in the bay.
Re: Conquest to victory [Re: FuryUs] #212520
02/10/09 01:20 PM
02/10/09 01:20 PM
Table Rock Lake Missouri
furious Offline
furious  Offline
good for you, this is what I wanted to do with our 88 Conquest about 15 years ago. I look forward to watching your progress.
Re: Conquest to victory [Re: FuryUs] #212521
02/10/09 11:02 PM
02/10/09 11:02 PM
Wichita,KS
Wichita,KS
Very cool!
