Valvetrain Noise #212508
02/02/09 11:15 PM
02/02/09 11:15 PM
Tucson, AZ
73ChargerSE Offline OP
Tucson, AZ
I've got a '72 Duster with a 340 in it. The motor's got a clacking sound on the #6 cylinder on the intake side. If you put quite a bit of pressure on the rocker on top of the valve, the clacking goes away and seems to run a bit better. We took out the lifter and cleaned it out. After putting it back on, nothing changed. What could be causing this? We're trying to sell the car and the noise is very unattractive.
Thanks!
Paul
Re: Valvetrain Noise [Re: 73ChargerSE] #212509
02/02/09 11:23 PM
02/02/09 11:23 PM
The lifter is bad.
