Re: 86 D150 Oil Pan question.
[Re: lunacy]
#2130187
08/11/16 11:35 AM
08/11/16 11:35 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I have one from a '76 318 I'm not using.
I have mechanical Aptitude. I can screw up anything.
[Re: Mopar1970440]
#2137132
08/20/16 10:21 AM
08/20/16 10:21 AM
bboogieart
Lost and Spaced
Did you run it after the oil change? The filter will hold a quart and some stays up in the motor.
I measured two 318 motors. Both in pick-ups. One a '76 and the other an '82. The dip stick tube is 10"s. The dipstick itself is 28.5"s. That's to the ridge on the base of the handle. Not the whole thing. Just the part that goes into the tube.
[Re: bboogieart]
#2138432
08/22/16 11:16 AM
08/22/16 11:16 AM
Posts: 781 usa
Mopar1970440
usa
Yes we did run it...and checked it again, still showing way over.
[Re: basketcase]
#2138434
08/22/16 11:17 AM
08/22/16 11:17 AM
Posts: 781 usa
Mopar1970440
usa
should be a 5 quart pan, 4X4s had 6 quart. Owners manual says 5 quarts and add 1 quart when changing filter also for a total of 6 quarts. It does not say any difference between 2wd and 4wd.
[Re: Mopar1970440]
#2138955
08/22/16 10:24 PM
08/22/16 10:24 PM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
My 82 D150 4x4 318 showes the same thing, And I know for a fact that it's the factory everything. Not sure why it shows over full. but I run it like that and never had a problem.
