Correct Trim Ring 1970 Ply E body 15" Rallye #2124995
08/04/16 05:08 PM
08/04/16 05:08 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
My 'Cuda is coded for 15 x 7 inch Rallye wheels and with the polished trim rings, P/N 3461043. I've seen #3461043 trim rings advertised but they are listing them as being for a 15x6 1/2 inch wheel. Did Chrysler make two different size trim rings with the same part number? Or,is this actually the same trim ring just that someone thinks it is for a 15x6 1/2 inch wheel? Any information would be appreciated.
Re: Correct Trim Ring 1970 Ply E body 15" Rallye [Re: Imrare] #2125072
08/04/16 06:17 PM
08/04/16 06:17 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
When they narrowed them to 6.5" in the mid-70s they kept the same part number.
Re: Correct Trim Ring 1970 Ply E body 15" Rallye [Re: Imrare] #2125097
08/04/16 06:37 PM
08/04/16 06:37 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
and.....
When they were reproduced, someone pulled the specs for the 6.5 trim ring by mistake.
Re: Correct Trim Ring 1970 Ply E body 15" Rallye [Re: Imrare] #2125172
08/04/16 08:20 PM
08/04/16 08:20 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Make sense now...thanks for the information.
