Need a starter relay wiring picture #2124843
08/04/16 01:12 PM
08/04/16 01:12 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
Anyone have a labeled pic that shows what wires go where? I had one saved on my last computer but it crashed. 70 Satellite.
Re: Need a starter relay wiring picture [Re: fatsat] #2124882
08/04/16 01:52 PM
08/04/16 01:52 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
There are letters on the relay labeling what they are for. If you are using your original wiring, it generally will not mate up on the wrong terminals.
Dark blue wire (fusible link) to big bolt with battery cable
Yellow (ignition, start) to I
Brown/yellow trace neutral saftety switch to G
Brown (12 ga) wire (starter motor) to S
Re: Need a starter relay wiring picture [Re: fatsat] #2124889
08/04/16 02:12 PM
08/04/16 02:12 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
It's pretty self explanatory , all but 2 the wires have a different connector and they can only go to one connection point. The 2 wires with the same size connector can both only go to one place.
If you went to google and typed in what you are looking for you would get the picture .
Here is one I found , borrowed from dodgecharger.com
Mainstream Media is the new Pravda
Re: Need a starter relay wiring picture [Re: JohnRR] #2125089
08/04/16 05:28 PM
08/04/16 05:28 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
The green wire shown above would normally be brown on a B-body.
Re: Need a starter relay wiring picture [Re: fatsat] #2125090
08/04/16 05:30 PM
08/04/16 05:30 PM
None
71rm23 Offline
71rm23  Offline
None
Mymopar.com has them as well
Re: Need a starter relay wiring picture [Re: fatsat] #2125211
08/04/16 08:20 PM
08/04/16 08:20 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
My "green" wire on the G terminal is black. 74 Challenger; auto trans...
