70 E-Body Lower Windshield Trim Differences #2123951
08/03/16 12:03 PM
08/03/16 12:03 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
I'm searching for a replacement lower windshield trim piece (the trim under the wiper blades), and was told there is an early and late style/configuration. Does anyone have pictures or can describe the differences between the two styles?
Thanks!
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2123970
08/03/16 12:38 PM
08/03/16 12:38 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes - the 70 style has an extra screw hole.
You'll need to wait till Friday if you need pictures
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2123998
08/03/16 01:10 PM
08/03/16 01:10 PM
Indianapolis, IN
Indianapolis, IN
Ok, so that's the difference. Thanks for the info and Friday is no problem!
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2124008
08/03/16 01:23 PM
08/03/16 01:23 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Rob
I know there is a recent post on here that covered this so see if you can find it. Otherwise I'll try help you out on Friday.
Chris
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2124063
08/03/16 02:38 PM
08/03/16 02:38 PM
Indianapolis, IN
Indianapolis, IN
Great. I'll search for the post.
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2124176
08/03/16 05:53 PM
08/03/16 05:53 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
I have a challenger made in october 5th 69. I can get a picture tonight. .
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2124330
08/03/16 09:40 PM
08/03/16 09:40 PM
MD
floyd Offline
floyd  Offline
MD
The earlier style is on the bottom in this pic. Note the extra hole and the difference between the tabs on the rest for the wiper blade. There are some other differences with the other screw holes (not visible in this pic).
Re: 70 E-Body Lower Windshield Trim Differences [Re: floyd] #2124653
08/04/16 09:28 AM
08/04/16 09:28 AM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
You can see extra screw but tabs nothing like the lower picture.
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2124671
08/04/16 10:24 AM
08/04/16 10:24 AM
Indianapolis, IN
Indianapolis, IN
Thanks for the pictures everyone.
Floyd - The damaged moulding that was on my car (SPD 10/21/69) has the extra hole like your bottom pic, but the tabs the blades rest on have a different contour and look similar to your upper pic. Any idea why the tabs look different? What is the application of the moulding pictured at the bottom?
Also - What type of screws are used to mount it to the cowl? I'm thinking mine are incorrect.
Rob
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2125854
08/05/16 04:44 PM
08/05/16 04:44 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
The picture of hemi orange car is a 70 challenger 440 mag r/t
Re: 70 E-Body Lower Windshield Trim Differences [Re: ct440rod] #2126100
08/05/16 09:30 PM
08/05/16 09:30 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there are at least 3 different e-body lower windshield trim pieces, extra hole, vertical VS. horizontal slot & "rounded" wiper rest scope
Re: 70 E-Body Lower Windshield Trim Differences [Re: 6bblgt] #2126101
08/05/16 09:31 PM
08/05/16 09:31 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
unfortunately I don't know what any of these are off of
Re: 70 E-Body Lower Windshield Trim Differences [Re: B5Cuda440-6] #2127037
08/07/16 11:44 AM
08/07/16 11:44 AM
Indianapolis, IN
Indianapolis, IN
Dan
Thanks for the comparison pictures…that’s a huge help! I've seen the horizontal slot type, but have not observed the vertical type on a car. Interesting…
