good drill bit needed #2123109
08/02/16 01:17 AM
08/02/16 01:17 AM
RapidRobert Offline OP
to drill rocker shafts (1/8). got a carbide drill bit ($5) & just started on it for a minute & the bit wants to skid off of the curved surface so I may have to file a very small flat to get it started but I'm wondering if it is going to be hard enough to do the job. your thoughts please.
Re: good drill bit needed [Re: RapidRobert] #2123115
08/02/16 01:26 AM
08/02/16 01:26 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Was it from an industrial store? or from a homedepot/lowes? A true tungsten carbide bit will be hard enough, a plated one may not. You may need a starter bit to get you going.
https://en.wikipedia.org/wiki/Drill_bit#/media/File:CenterDrills123456.jpg
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: good drill bit needed [Re: astjp2] #2123118
08/02/16 01:28 AM
08/02/16 01:28 AM
I'm thinking it was an "Irwin" in a yellow blister pack from a true value hardware store. there is a graingers close by if need be. EDIT tomorrow I will try a mini bit to get a hole started if it will start the hole
Re: good drill bit needed [Re: RapidRobert] #2123119
08/02/16 01:28 AM
08/02/16 01:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Beriliaum(sp) bit.. super hard... hope you doing
it in a mill... also a small center bit
wave
Re: good drill bit needed [Re: MR_P_BODY] #2123120
08/02/16 01:30 AM
08/02/16 01:30 AM
mini drill press/drill press vise/shaft wrapped/clamped in a rag
Re: good drill bit needed [Re: RapidRobert] #2123133
08/02/16 01:57 AM
08/02/16 01:57 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The shafts are probably nothing special, just thicker for strength. Chrome moly - no big deal to drill through. But you do have to get it dead nuts centered on the shaft.
Re: good drill bit needed [Re: Stanton] #2123145
08/02/16 02:40 AM
08/02/16 02:40 AM
That's what I needed to hear!
Re: good drill bit needed [Re: RapidRobert] #2123168
08/02/16 04:19 AM
08/02/16 04:19 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Mcmaster Carr will have what you need in about 3 days....put the Irwin back so you have it for your dishwasher...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: good drill bit needed [Re: RapidRobert] #2123181
08/02/16 04:57 AM
08/02/16 04:57 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
McMaster-Carr, the toy store for men. boogie
Re: good drill bit needed [Re: RapidRobert] #2123276
08/02/16 11:01 AM
08/02/16 11:01 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Center punching where you wan to drill is a REALLY good idea on round material. When I drill round I center punch then I let the vice float on the drill press bed in case I'm off a fraction - the vice will move so the bit is centered into the punch.
Re: good drill bit needed [Re: RapidRobert] #2123303
08/02/16 11:40 AM
08/02/16 11:40 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Use a good solid clamp, and Hanson bit, and who ever is making the MAC bits are great.
Also since a rocker shaft is harder than typical steel use slow speeds and cutting oil, but you probably already know that.
Re: good drill bit needed [Re: RapidRobert] #2123329
08/02/16 12:08 PM
08/02/16 12:08 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
The rag isn't helping, use alum spacer blocks, if marking the steel rocker shafts is your concern.
Re: good drill bit needed [Re: RapidRobert] #2123346
08/02/16 12:29 PM
08/02/16 12:29 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Use V blocks if you have or can get them, center drill first, then good cobalt drill & use oil/coolant. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: good drill bit needed [Re: RapidRobert] #2123365
08/02/16 12:58 PM
08/02/16 12:58 PM
Moparnut426 Offline
Moparnut426  Offline
Ive had great luck in the past using a smaller piece of angle iron welded to a heavy flat that you can vice into the bed of the drill press, then you can use another clamp and hold the shaft into the valley. once you get one hole drilled you can drill through and put a bolt in that hole to keep the shaft the same.
Re: good drill bit needed [Re: Stanton] #2123377
08/02/16 01:22 PM
08/02/16 01:22 PM
I'm gonna get after it today. this is the last fabbing needed on this 360. thanks guys!
Re: good drill bit needed [Re: RapidRobert] #2123382
08/02/16 01:26 PM
08/02/16 01:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Have you tried centerpunching it to get a location and prevent the bit from skidding around? That's a good way of getting an idea of hardness. If you can't get a centerpunch mark in it, you may have a tough time getting a drill bit through it. Is the shaft hard chromed?
Re: good drill bit needed [Re: RapidRobert] #2123392
08/02/16 01:49 PM
08/02/16 01:49 PM
Moparnut426 Offline
Moparnut426  Offline
I had to go to 3/8 from 5/16 on a set once and couldn't touch them with a bit, Needed to go to a machine shop and drop a 25/64' end mill through them then chamfer with a die grinder.
Re: good drill bit needed [Re: Moparnut426] #2123441
08/02/16 03:01 PM
08/02/16 03:01 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
Cobalt from Grainger item# 1G865
Yes I live in Michigan, so there is still 1 light on
Re: good drill bit needed [Re: RapidRobert] #2123566
08/02/16 06:23 PM
08/02/16 06:23 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
Carbide is the chit. careful on 'breakthrough'!
A nice carbide ball endmill is great if you happen to have a boss like mine?
Re: good drill bit needed [Re: 440dart] #2123833
08/03/16 02:00 AM
08/03/16 02:00 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Colbalt probably wont do too well, carbide to get through the hardened outer surface.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
