Re: 1.6 bad geometry
[Re: Thenwhat85]
#2122917
08/01/16 09:37 PM
08/01/16 09:37 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
A good read on TD machine website. Geometry on a shaft rocker is dictated by three items. 1 Shaft center to tip length 2 shaft height 3 valve tip height
TD makes their own stands and rockers for application. They have different length rockers as well as stands for those lengths. Plus shims to correct for valve height.
Lot of stuff not used on stock style stands. But, an educational read.
[Re: Thenwhat85]
#2122941
08/01/16 09:57 PM
08/01/16 09:57 PM
Challenger 1
Cincinnati, Ohio
No way I would run 1.6 on a mopar, why? Spec the cam for lift and duration you want running 1.5 rockers. You will be a way ahead like your friend says/recommends Your not building a pro stock motor, way too many motors/heads/cams have been messed up with 1.6 rockers on mopars and some folk don't even know it when it happens to them. They blame everything else. You don't need 1.6s and they are more trouble than they are worth in your case. Too bad you spent so much time grinding those heads when you can run just as fast with 1.5s I promise.
[Re: Thenwhat85]
#2122949
08/01/16 10:09 PM
08/01/16 10:09 PM
Posts: 43,347 Bend,OR USA
Cab_Burge
Did you try shimming the rocker arms first to move them away from the heads to make clearance? I use 1.6 ratio on both stock and after market aluminum heads a lot and I have had to grind some on a lot of the aluminum heads to get clearance, not so on other brands I can't remember grinding on a stock head to clear 3/8 pushrods with 1.5 up to 1.7 ratio rockers The Edlebrock RPM and the Super Victor Max Wedge heads both needed grinding on them to clear, especially the Victor M.W. heads with both the Hughes 1.6 ratio rockers and then later with the 1.6 ratio Harland Sharp rockers I replaced the Hughes with
[Re: Thenwhat85]
#2123667
08/02/16 09:22 PM
08/02/16 09:22 PM
crabman173
crabman173
Promaxx same as Sidewinder etc Great heads for the $$ but Sidewinders available for way less--1.5's are pain in a@$% with 3/8ths most running a Smith or Trend etc 5/16ths pushrod to make life easy--1.6 is not faster in most Mopars just a real PAIN --Sidewinders and Promaxx worse than Eddys in that dept just run a 1.5 you guys!!!!! Getting them 10000% on paper is an exercise not a way to go faster or ??? Just keep it simple please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Sidewinders are very wide at top of port and not suitable for 3/8ths unless you grind a lot ( more than Eddeys_ get some Smith 5/16ths they SWEAR are good for extreme pressure at the length needed for those heads and RELAXXXXXXXX
[Re: Thenwhat85]
#2123681
08/02/16 09:48 PM
08/02/16 09:48 PM
Posts: 4,213 New York
polyspheric
New York
No production pushrod engine made in the last 30 years still uses 1.5 rockers, and certainly no race engine. Why would the intake and exhaust sides need exactly the same cam lobe, lift and rocker ratio? They don't - they're 2 completely different systems. It's just the cheapest way to make them, and it's a coincidence if it's still true when the engine has been modified. Bigger intake rocker always helps if the cam isn't big enough (specially if the LSA is too large), but bigger exhaust generally does nothing.
Leon441's remark is correct but a bit short. What is always present, but neither visible nor revealed by the manufacturer: exactly where do you put the rocker shaft hole WRT the pushrod seat and roller axle? Hint: it's not in a straight line unless your name is Miller, and how far away the line is "bent" determines the geometry. If this makes the roller tip do something you don't want it's not fixable.
Boffin Emeritus
[Re: Thenwhat85]
#2123693
08/02/16 10:14 PM
08/02/16 10:14 PM
crabman173
crabman173
We aren't using new modern engine science we are using a block and heads designed in the 50's for 250 HP and most of the cheapo heads hate 1.6 ratio because the pushrod hits the intake port so WHY fight city hall-- run a 1.5 on these Dinos and keep on melting tires without the hassle is my point when is an easy 500-550 HP not enough for a fun street engine? Answer--Never unless you just read too much
[Re: Thenwhat85]
#2123716
08/02/16 10:43 PM
08/02/16 10:43 PM
polyspheric
New York
I agree, pushrod clearance has to be dealt with, and if you can't fit a 3/8" pushrod using 1.5 rockers and a bigger cam is the answer. A 5/16" pushrod isn't going to make it, no matter what un-obtainium and .150" wall thickness - the stiffness is 90% in the diameter.
Boffin Emeritus
[Re: Thenwhat85]
#2123768
08/03/16 12:20 AM
08/03/16 12:20 AM
crabman173
crabman173
It ain't Junk if they are quality casted aluminum with quality bronze guides that make easy 500-600 HP at half the price of some that are better That is not an opinion--that is a fact Or to put it another way Charlie Buck built an engine that went 3.52 in 1/8th last month---while that is an awesome deal it is not what most of us need--most of us needed a cheapo head that would make 500-600 HP for cheap--It took a Sidewinder to shoot down the truly crappy Stealth--The Steven produced Sidewinders ( or if you buy enough you can name anything you want) are that head--Get a CNC to write your name on them and work to send out heads with quality parts and valve job and you have Promaxx, Sidewinder,and maybe some yet to come but the fact is they are as good or IMO better than the Eddy for a killer price--they are quality castings something that can't be said for Stealth They are sold for the most part by Mopar parts vendors that STRIVE to take care of customers and send out good parts not corporate folks that could care less--they are made by new wave enterprising folks that put it all on the line to make a buck and be part of the march forward to more for less--that is the way the world economy is heading--now more power to the enterprising USA makers too--I really like the Summit head--I do--and will use anything I can over an Indy but fact remains that the imported castings on the Promaxx and Sidewinders are far better than the previous import choices --much like other import things like rods etc that have improved a ton over time-- R&D on a 550 HP build Mopar street engine is funny--ya don't need any just build it and have some fun! That is what this was all about--Building the 700-1000 HP units for street is just an ego trip--so what's next 1400 HP pump gas engine? Who cares? The meat of the market is a guy that wants a classic Mopar body, cam sound, and melting tires with an orange lump under the hood Sidewinders meet that need and leave him some extra Loot so he can treat his date right. AND... If Smith Bros say that a 5/16th will do the job--buy it and relax--yea it will not win the Spintron contest but I have plenty running around with street rollers and they seem to be doing fine
[Re: ]
#2123916
08/03/16 10:56 AM
08/03/16 10:56 AM
Posts: 561 USA
B3RE
USA
I love this idea that Mopars are so outdated, that you should only run 1.5 rockers. If that were the case, I could make the argument that you should only run a flat tappet cam, because big blocks never came from the factory with a roller cam. A roller cam has the ability to increase area under the curve with the same seat timing, which is exactly what a higher ratio rocker does. For that matter, the dinosaur Mopar engines never had roller rockers from the factory, so you shouldn't be running those either. Forget about aluminum heads and manifolds. Headers, no way!
I almost never use a 1.5 ratio rocker on my Mopar builds, and I don't seem to be hurting for power, reliability, or stabilty. I put the shafts in the right place, and it makes the rocker to valve geometry correct. There is no roller rocker that can be bolted to the cast in stands, and have proper geometry, no matter how much they are marketed as such. Do a Google search for Mopar rocker geometry. There are some good tech articles available, as well as some not so good. Use logic and common sense to separate the two.
As far as pushrods are concerned, you can get away with less pushrod when the rest of the valvetrain is stable. A smooth stable valvetrain puts less of a pounding on its individual parts.
In response to Polyspherics comment about Miller, if you study his (Millers) explanation of geometry, he tells you that even though the pushrod side may not be correct on other rocker brands, and is difficult to change, the valve side is far more important. So, if you don't correct the valve side, you lose twice. Also, I'll share a little secret. Miller's patent expired over 20 years ago.
Run the 1.6s with the shafts in the right place, and you won't have excessive guide wear or instability issues.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#2123919
08/03/16 11:06 AM
08/03/16 11:06 AM
Challenger 1
Cincinnati, Ohio
Run the 1.6s with the shafts in the right place, and you won't have excessive guide wear or instability issues. Since it is not a easy deal or economical for the OP to move his rocker shafts on his budget heads, don't you think he should run 1.5 if he wants to keep the cost down and make it reliable as possible without spending big bucks to run 1.6?
[Re: Challenger 1]
#2123923
08/03/16 11:17 AM
08/03/16 11:17 AM
Posts: 561 USA
B3RE
USA
Run the 1.6s with the shafts in the right place, and you won't have excessive guide wear or instability issues. Since it is not a easy deal or economical for the OP to move his rocker shafts on his budget heads, don't you think he should run 1.5 if he wants to keep the cost down and make it reliable as possible without spending big bucks to run 1.6? Believe it or not, with the reduced lift from the 1.5s, his effective geometry would be worse. Depending on the approach, moving the shafts is not that expensive, and might save some grinding. Also, he already has the rockers, so replacing them would be an additional cost.
Mike Beachel
