Re: Black oil in 3k miles in our 6.1L 300C Engine?
[Re: Jeremiah]
#2122421
08/01/16 04:03 AM
08/01/16 04:03 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Which Synthetic 5W40? Most guys use the Mobil 1 Euro 0W40 or Rotella T6 5W40. They originally were spec'd with 0W40 Mobil 1, now its Pennz Ultra 0W40 or 5W40.
Mopar to the bone!!!
[Re: WO23Coronet]
#2122482
08/01/16 11:01 AM
08/01/16 11:01 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I agree with Coronet. Short trips are usually the cause of darker than normal oil. Keep the factory thermostat as a lower temp one will just make It worse.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 72Swinger]
#2122506
08/01/16 11:41 AM
08/01/16 11:41 AM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
Which Synthetic 5W40? Most guys use the Mobil 1 Euro 0W40 or Rotella T6 5W40. They originally were spec'd with 0W40 Mobil 1, now its Pennz Ultra 0W40 or 5W40. It uses Penz or Valvoline 5W-40. I guess it's not black like you would be in a carb'd engine but I have seen endurance engines come off of a road race track with oil that looked less cooked that this does. Maybe I'll try switching it to Redline and see if it helps.
[Re: WO23Coronet]
#2122513
08/01/16 11:44 AM
08/01/16 11:44 AM
Jeremiah
Rogue River, OR
If you short trip it/seldom use it and don't get the oil hot enough to burn off the condensation it's goes black, putting in a 180 stat will probably make it worse. My 05 Magnum R/T has the factory stat and is usually around 195-205 on the gauge, and it doesnt get short tripped, generally a minimum of 40 minutes of run time. I change oil at the 5-6K mile mark and while the oil is dark it's by no means black. Our driveway lane is 1.5 miles long and the first small town is another 10 miles....then you hit the freeway. The one thing we don't do here is take a short trip lol. In fact, this car is only put into duty for for road trips/vacations which is why it only has 40k on the clock. It rarley leaves the garage and when it does it's usually a 2k mile trip with a light footed driver (not me).
[Re: Jeremiah]
#2122645
08/01/16 02:41 PM
08/01/16 02:41 PM
72Swinger
Nebraska
I use Rotella T6 5/40 in mine, the truck and wifes car have Pennz Platinum 5W20. Just a slight change in color from new to 3000 miles.
[Re: Jeremiah]
#2122743
08/01/16 04:42 PM
08/01/16 04:42 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
We don't use K&N in this household. Way too dusty around here. Car is bone stock down to the tires. Good Man. Check the factory filter to be sure you have it seated in there properly. One of my vehicles had a complicated setup and it let a trickle of dirt in. Oil went black in no time.
Mo' Farts
Moderated by "tbagger".
[Re: dogdays]
#2122995
08/01/16 11:02 PM
08/01/16 11:02 PM
Jeremiah
Rogue River, OR
You are making an awfully big assumption by deciding whether the oil is good or bad depending on the color. Get the oil tested by one of the oil test companies, for wear metals, particulate and water/antifreeze. It doesn't cost that much and is quite worthwhile.
R. That is a good point, however I was fishing for someone else with a similar experience. My immediate assumption was the increased engine operating temp ( >200 degrees ). At this point it is most likely a non-issue.
[Re: Grizzly]
#2122997
08/01/16 11:03 PM
08/01/16 11:03 PM
Jeremiah
Rogue River, OR
We don't use K&N in this household. Way too dusty around here. Car is bone stock down to the tires. Good Man. Check the factory filter to be sure you have it seated in there properly. One of my vehicles had a complicated setup and it let a trickle of dirt in. Oil went black in no time. Thanks, that is a good idea. I'll check the intake tract and report back if I see any sign of filter bypass.
[Re: Jeremiah]
#2124602
08/04/16 02:45 AM
08/04/16 02:45 AM
72Swinger
Nebraska
There are many, I bought a Billet Tech from Speedlogix and then also installed a UPR diffuser inside it. Might get about 2-3 tablespoons in it between oil changes, 1-2000 miles.
